Hi you lot....can anyone help!!!!!
Ive put several posts on here about this problem so rather than going over it from the thread to the needle can I ask any of you that think they may have valuable input to have a look over these to see what you think.........but in a nut shell.......
After months of silly electric faults my CLK 320 (2000 'W') refused to allow the key to turn so was hauled off to an indy........about 4 weeks ago where it still is!!!
the diagnostic port was not talking to the star and it was found that the K40 fuse/relay unit had suffered water damage, so it was replaced, the car still didn't work but several things including the OBD port were now talking to the STAR, the ECU was checked and found to be swimming in water. It was sent away for repair but it came back as unrepairable.....so a 'kit was bought for £250 from a breakers with the ECU, EIS, steering lock and key but it turned out to be from a 1999 not a 2000 and even though I had given the indy all the numbers and he had checked with Merc that it was compatible it wasn't!! so £1250 was forked out for a new ECU from MERC, this should cure the fault right...WRONG!!!
the indy phoned today to say that the key still will not turn and that when the ECU went (water ingress had caused a component to blow and according to the firm that specialize in there repair it must have caused further damage to the ECU) it must have taken out the EIS unit as well which is £340 plus another £180 for some dam orange key that's needed to program it!
Im at the end of my rope now, how can another unit have been damaged when the ignition was off? It was taking longer and longer the the ket to turn the weeks prior to the breakdown, about 3 seconds but is that the EIS or the ECU at fault?? (chicken and egg i know!) could the EIS being faulty have damaged the ecu? what if I fork out for a new EIS unit and he then tells me it needs something else such as the steering lock, I paid £220 for a new key a few months ago after I dropped it and now im SKINT !
The indy also said that he can not fully diagnose things as the ignition is off!!
Am I being strung along?? I know that the battery had gone flat, and im calculating that it cant have been on charge for more that 4 hours so could it be that there is not enough voltage in it to start the car or is there some 'synchronizing' that needs to be done regarding the key and the new ECU....
as always your help is appreciated!
