alffa164
Hi, i just got a 1998 C240 Sport (manual transmision) and i did have problems with the A/C. When i bought it the guy told me the A/C wasnt cooling very cold, in fact... it wasnt cooling at all.
I just took it yesterday to an A/C workshop and they discovered two leaks and they were extremely easy to fix. The experience this guy has made him discover the leaks in less than 1 minute and he told me:
" This model of MB has problems with the O-rings in the freon gas line, specially in the one that goes from the refuelling valve on top to the compressor and the other one is the located on the tube that goes from the compressor to the condenser"
He took out both of the tubes and the o-rings were really really bad, so he changed them with some VW o-ring he had lying around and problem solved (leaks).
Then he charged the 134A freon gas and i turned on the car, then the A/c at full power and the compressor started doing a funy noise... tac-tac-tac-tac-tac-tac.... so this means i need a new compressor????
The guy put some A/C oil in the line to check if the compressor just needed some lube but the tac-tac-tac sound was still there. Any ideas????
If anyone has any idea where can i get a not too expensive one i will highly appreciate it!
