Ali Fox
- Oct 14, 2017
- 1998 E300 TD - 1989 609D TRUCK!
Having been a member for a full 6 hours here's the first question, I've done a lot of research and can't be certain so please forgive if this is a dumb question. Does the hydraulic system determine ride height whilst UNLOADED?
The project sits lower by a good six inches on drivers side rear - I've had a quick look, no obvious leaks, shock seems recent, not damp [maybe some very light "misting" in that the dirt polishes off nicely] spring seems good with no cracks breaks etc.
Now this motor has definitely been neglected, the fluid was only just touching the bottom of the filter/pickup.
Could the accumulator be bad on that side? Would that cause the sag?
Actions so far:- Squrted the levers/valve with WD40 and ordered 2 litres of fluid - I'll soon be spending plenty of time under there replacing ABS ring.
Thanks in advance,
Ali
Thanks in advance,
Ali
