I have a blocked windscreen nozzle. I have taken it off and the water flows freely from the pipe. I have put a pin in the nozzle to clear it, but it will not work. I have tried blowing in it, but it seems blocked. Any ideas?
I had a similar problem with my R170 last week. A pin was no good so I got a paper clip, partially unfolded it and used that with some real brute force and a twisting motion. You need to insert it about 2cm or more.
I had the same issue and in the end just soaked the jets overnight in a glass of drain unblocker. They were still bubbling away 5h after putting it in as all the stuff reacted with it (one was so blocked it had no hole at all and you couldn't tell where it would have been). While they were off I put the hoses into some plastic bottles and ran drain blocker through the whole system too. No problems since, mind the drain unblocker here is rather industrial strength and will burn the skin instantly upon contact so not sure it's available in the UK?
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
