Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
Sequence of events , OK had the headlight bulbs changed by Mobilo proper MB technician ...
All was well.
Went for 16 mile drive all was good.
Gremlin 1.
Came hone opened boot and heard a sound like a fan running in the left rear wing.
Pressed button to shut boot .. it only went half way down! still could hear fan noise running )
Pushed boot shut and opened and closed , all worked fine no fan noise. Tried 5x all well including clever tricks like shutting boot with keys in it ... shuts then pops open as it should.
Self sorted !
Gremlin 2
As the car has been stationery for a few days decided to give it a top up charge.
Checked voltage 12.6V to 12.7V ( 6 month old battery about what I expected ).
Did the full monty AC off, Comand off, Keyless Go Button out, ign. Keynturned left and removed.
Waited till the current drain shut down to 20mA.
Put on CTEK checked voltage 12.8V and 3.59A as it should be.
One slight mistake put CTEK in its normal position, corner edge touching on the air intake tube, which was slightly warm.
As usually paranoid about this charger as it can get warm, checked later ant it was 13.7V and 3.59A
Imwas expecting about 14V and maybe a circa 3A by now.
Then touched CTEK and it was very hot. So moved it away from luke warm air intake tune abd cooled with a cold wet towel, cooled down in 3 mins.
Rechecked it had gone to 14V and 2.68A more like normal.
So I assumed maybe it was just ready to drop the amps or being warm it had constrained its voltage.
Not too worried
Had to go to the shops turned on engine
The dashboard says "ABS and ESP Not Currently available!
See owners Manual"
OMG tried it with and without key / keyless go button.
Still same message.
**** had the CTEK got too hot and fried something. Expensive!
So put the CTEK oncharge again 13.7V and 2.68A. All OK
>>>> I assume had the CTEK got too hot hopefully it would shut down, saya it has protection in it.
And in any event it couldnt self repair itself could it?
Decided to go for a drive ...
Stopped, turned of engine, 0 Messages ... thats odd?
Then ign key pos 1 just the airbag light, ign key pos 2 All dash lights .
Press KLG again all off , put in P ... locked car . All per normal.
Then got in and pressed brake and pushed (very nervously) the Start button ... vroom .. everything fine! No messages No ABS and ESP warning message.
Tried it 8 times All Perfect!
WTF is this just a glitch or is it indicative of something nasty?
I would normally put this down to coincidence, and a computer glitch.
But as its at my Indy's on Thursday is it worth paying them to look on STAR ?
All was well.
Gremlin 1.
Self sorted !
Gremlin 2
Not too worried
See owners Manual"
Still same message.
