Wayne Lovell
- Oct 25, 2017
- C200 Kompressor/2004/ 1800 cc
Hi there,
Please can someone help me out, I have recently purchased a 2004 Mercedes C200 Kompressor 1800cc, the problems I'm having is the car will not start with the key, the key goes in to the ignition and turns so the dashboard lights do come on but will not crank the engine, I have sent the ECU off to a recommended repair centre and they cannot locate any faults with the unit. I have now replaced the SAM unit under the bonnet with the correct item and still the same issue. after reading on one of the forums it stated if I removed a certain relay and link the two pins with the ignition on the engine will crank over and start, I tried this and it has worked, please can anybody suggest anything that may help me out??
I have attached a picture to explain which relay I have mentioned!
