2005 CLS 500 transmission lines
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by matteb63, Sep 12, 2017.
  1. matteb63
    matteb63 Senior Member
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    Cl 500s & CLS500 with LPG conversions
    My Indie wants to replace the transmission lines that connect to the rad at the front...He has told me he needs to take off the front bumper to do it and that i may need a new rad as well if the connector is seized.
    Has any one any idea if this is something i can do myself or is it really that difficult? has anyone got a procedure breakdown please?
  2. Arzaam
    Arzaam Senior Member
    639
    39
    Oct 13, 2014
    Pakistan
    Your Mercedes:
    W203 2002 c180
    are the lines leaking? and yes the radiator may need to come off if there is not enough room, sometimes the connector seizes and breaks when opening but shouldn't happen if careful, I am no expert but thats my opinion, maybe someone else here can also give an input
    matteb63 likes this.
  3. star
    star Forum Supporter Authorised Forum Supporter
    4,669
    206
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    It's a fiddly job, easier with rad pack out. They are just a ouch and snap in firing and can corrode badly.
  4. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    Yes the lines are leaking.
    And if I can replace them without removing the front bumper even better..
  5. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    has anyone got a diagram that will show me the parts i need to order...there are two lines at the bottom back of radiator that appear to be bolted there and have union joints from which they go up to the rad..i guess i need part numbers our names to order them in but haven't been able to work out what they are as yet?
  6. Arzaam
    639
    39
    Oct 13, 2014
    Pakistan
    Your Mercedes:
    W203 2002 c180
    does this diagram help? you can tell me the item number form it that you require and I can let you know the part number and name. B50600000066.090923-2.png
  7. Arzaam
    639
    39
    Oct 13, 2014
    Pakistan
    Your Mercedes:
    W203 2002 c180
    discard the M156 pic on the right as yours is the M113 motor I believe
  8. star
    4,669
    206
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    Omg I hate predictive txt. They are just a push fit, and the fitting can corrode in the rad.
  9. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    so managed to get part numbers 10 and 20 from mercedes newport for £54using the diagram above..great help and will attempt fitting tomorrow..i will release the rad and hopefully that will give me enough access to remove the lines without damaging their sockets.
    Arzaam likes this.
  10. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,222
    537
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Mercedes-Benz C32AMG, SL55AMG, C320CDI Sport Edition Estate and SLR McLaren Coupe Roadster.
    I always take the bumpers off, it doesnt take long and I hate struggling.
    I find you try and short cut by not taking something off, you end up spending just as much time struggling in a tight space. Stuff that.
    silestanix and matteb63 like this.
  11. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    how do you take the bumper off is there a step by step procedure i can follow?
  12. LostKiwi
    LostKiwi Senior Member
    12,198
    4,233
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Hopefully this will help.
  13. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    bumper came off easily and i managed to change lines although the top line was almost welded in and required delicate manipulation to remove without damage....
    Changed the filter and cleaned sump....filled with 6 litres of transmission fluid. Started it up but no drive in any gear....wondering if i crossed lines at bottom of rad but would this make a difference and is it possible that i over filled it.I was unable to find a drain hole on the torque converter so assume it dosent have one. there is a fill tube at the back of the engine.
  14. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    This diagram isn't appearing to show which Radiator end tube goes to which line..it appears to suggest that it dosent matter.
    Parts changed where number 10 and 20
  15. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    the lines attach to the transmission on opposite sides which isn't obvious from the diagram and there are no banjo fittings at transmission..i currently have the lines hooked up with the lower radiator connector running to what appears to be lowest union with transmission..passenger side
  16. star
    4,669
    206
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    Did you fit the filter correctly and it hasn't dropped. Why fill with 6ltrs oil if you didn't drain tc?
  17. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    Wow how stupid do i feel!! ok so i filled the transmission with nothing...just added 6 litres of expensive transmission fluid through the oil filler at the back of engine ....guess i have too fill it from the drain hole. I'm assuming that when it overflows from the drain hole its full?
  18. star
    4,669
    206
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    A little knowledge is dangerous and could have been costly if your engine had run away because of overfill of a gallon. As we now know it's a 7speed, it's filled from under the car. Did you leave the pedestool attached to sump?
  19. OP
    matteb63
    295
    6
    Mar 3, 2007
    Abergavenny Wales
    Your Mercedes:
    Yes pedistool is still attached see
  20. Steve@Avantgarde
    6,222
    537
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    I have seen this done so many times its frightening. Best be draining the engine oil out double quick time as well.
    The level is set based on temperature and flow from the sump bung. That is why the pedastool is there. It is filled from the sump bung yes. The oil level is set with the transmission no more that 50'c
Share This Page
