2005 sport edition front arb
Discussion in 'Suspension, Steering & Brakes' started by e55amggary, Feb 2, 2018.
  1. e55amggary
    e55amggary Senior Member
    263
    13
    Feb 2, 2009
    Bristol
    Your Mercedes:
    C220cdi sport edition Auto / A6 2.7tdi Quattro s line Avant
    Evening Folks
    Still getting the missus w203 up together
    Anyway the front anti roll bar bushes are knackered.
    Been informed i have to buy the complete bar with bushes molded on + new brackets.
    Now its not a fortune to buy from mercedes, but just wondering if there is a cheaper option as the pennys are tight at the moment
    Thank you
  2. LostKiwi
    LostKiwi Senior Member
    12,183
    4,224
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Try ECP or GSF.
  3. OP
    e55amggary
    263
    13
    Feb 2, 2009
    Bristol
    Your Mercedes:
    Tried the above
    Everytime they supply the incorrect bushes.
    Sport edition has a different size arb that they do not stock
  4. John Laidlaw
    John Laidlaw Senior Member
    14,643
    3,013
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    Try autodoc- you can download an app which helps a lot too
  5. mercedes13156
    mercedes13156 Senior Member
    1,213
    171
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    CLK 200 Cabrio and a Ford Kuga
    Take one of the clamps off once you get both wheels off the ground. There are two different shaped rubber bushes. Once you know which ones you are looking for, get onto EBay. They're only a few pounds each and easy to replace. I think the anti roll bar itself is the same diameter for both standard and sports, just the rubber bushes that are different. If all else fails, remove the old bushes, wrap the roll bar with duct tape and replace the old bushes and the gaps will "disappear". It's a temporary fix and should last you a few weeks until you get it properly sorted.
  6. OP
    e55amggary
    263
    13
    Feb 2, 2009
    Bristol
    Your Mercedes:
    The bushes are moulded to the bar on the sport edition
  7. mercedes13156
    1,213
    171
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    You can cut the moulded bushes off the bar, clean it up and replace them with new ones. In terms of the difference between the normal and sports ARBs, if I remember correctly, the normal one is 28mm diameter and the sports 29mm diameter.
  8. OP
    e55amggary
    263
    13
    Feb 2, 2009
    Bristol
    Your Mercedes:
    Which arb bushes do i buy ?
    Thanks for the input
  9. mercedes13156
    1,213
    171
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    The one that fits the clamp holding it to the chassis. There are two types. See below. I'm fairly sure these are the ones. The clamps only fit one type of bush. It's obvious when you remove the clamp.
    [​IMG][​IMG]
Share This Page
