Droverunner
- Aug 2, 2017
- Location
- West Cambridgeshire
- 2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
Going to fit a new thermostat (plus aux belt & tensioner) to the 2007 CLK 220CDI tomorrow.
I wondered about the correct coolant. The handbook refers to info sheet 310.1 which I found online and for our engine gives a MB coolant spec of 325.0 or 326.0. Looking up products listed on those sheets (such as Comma Xtreme G48) I see it is a glycol mix and the makers of the antifreeze only advise a 3yr life... but MB give a 15yr life. Odd??
Also re the stat change. Any tips where a couple of litres can be drawn off to save spillage. Looked on the forum for a procedure and several how-to guides mention a short hose on the bottom of the stat than can fall in the undertray as you pull the stat away. But the new stat has no connection underneath for another coolant hose... and I can't see one on the old stat looking at the engine. Also if it just falls away with no clip holding it on surely it can't be a coolant hose?? Puzzled??
Finally does it self bleed when the job's done? There looks to be an elec coolant pump clipped to the front of the expansion tank... or am I mistaken?
