karllap
Hi, I have bought a 2013 E220 which doesn't seem to have any kickdown or if I put it in manual mode the I can't manually change the gears. It also doesn't really feel any different in sports mode though because I have only had the car a few weeks I don't know how much of a difference it should make.
I know this sounds weird but it also feels like it should change gears more readily than it should. When I have had auto's before you can normally manipulate the accelerator to change up or accelerator a little to change down but it doesn't and lastly it doesn't like going into 7th. I have to do over 80mph before it drops in to 7th
What is really bizarre is today I was just about to pull of from the lights when everything just went of for a second and the radio / sat-nav screen went purple (as though everything just reset) but the gears started working ok!
It only lasted for about 5 minutes though then back to not working.
The car comes with a receipt for work done to the EGR and DPF so not sure if this could have anything to do with it or could be a complete red herring
The car drives lovely but just weird issues with gears
