230TE REAR WASH - DUFF SWITCH
Status
Not open for further replies.
NormanB
Portsmouth UK
Following on from the recent success (with Andy's help) in sorting out the console illumination - I would like to share my next problem with you in the hope someone can shed some light on it (awful I know).
The scenario is as follows:
1.Rear wash pump does not run when console switch closed.
2.Swap rear wipe switch to pump switch position - pump runs when console switch closed.
3.Initial diagnosis: Duff switch - (confidence level 10).
4.Buy new switch from stealership, fit it, but rear wash pump does not run when console switch closed (Eeek!!).
5.Repeat Step 2 - pump runs when console switch closed.
6.Diagnosis: Duff switch - (confidence level 5).
7.Obtain a replacement switch from stealership, fit but rear wash pump does not run when console switch closed (Double Eeek!!).
8.Repeat Step 2 - pump runs when console switch closed.
9.Diagnosis: Duff switch - (confidence level -1).
Stealership refused to accept that 2 new switches could be faulty - and I have to agree really. Anyone any thoughts/advice on this one?
VMT
NormanB
PS: One bonus to all this is I can now get the console out in about 90 seconds!
N
NormanB
Portsmouth UK
  • #2
230TE REAR WASH
No takers then -??
The only other thing that I was thinking -   might be the cause --- but cannot figure electically speaking ---is that my rear wiper is duff - needs new motor and awaiting funds - and when I move the wipe switch over to the wash position, the wipe sw socket is empty and so linkage with the motor circuit broken. Not explaining very well - but if rear wash is linked logically to rear wipe (like front wash linked to front wipe) - then maybe I didnt have a duff switch after all - Eeek!!
Any advice/opinions welcome.
NormanB
N
NormanB
Portsmouth UK
230TE REAR WASH
I can take it that either this is very unusual or I am just unlucky - OR should I just hit the dash with a hammer!;-)
NormanB
ant748
rugeley
230TE REAR WASH
No expert but have you checked your relay in back door?My wiper motor had seized but the washer worked in both positions,only problem is there is a hole in the pipe and water floods down the a post!oh well another little job!p.s a chap on e-bay is selling second hand wiper motors for £50,if your intrested i'll look up his e-mail adress.
N
NormanB
Portsmouth UK
230TE REAR WASH
Thanks ant748.
As I said the wiper switch when transposed into the wash switch socket is able to operate the washer so I guess that is a good functional check of the relay.
Yes would be interested in second hand wiper motor - I would be grateful for details you mentioned.
Cheers
NormanB
ant748
rugeley
230TE REAR WASH
The chaps e~mail adress is nick.mercedes@ntlworld.com   I was after some amg alloys for my car on e-bay and noticed he had a lot of stuff on there for sale.I was after a wiper motor as well so I asked if he had one,by the time the reply came I had located one at a breaker in Birmingham so I got that one instead.Good Luck!!
N
NormanB
Portsmouth UK
230TE REAR WASH
Hi Ant
I have emailed him already!
VMT
NormanB
N
NormanB
Portsmouth UK
230TE REAR WASH
Hail to the forum
Thanks to Ant748 and nick.mercedes@ ntlworld.com I now have a functioning rear wiper motor.
I have posted to close the loop on the thread. I postulated above that the rear wash function may have been inhibited electrically by the duff motor and it appears that is the case.
When I was swapping the switches over, by leaving the wiper switch socket empty I was defeating some circuit or other (I haven't got a wire diagram).
How will I dare show myself in the stealership again;-)
Regards and good night
NormanB
Status
www.W140.co.uk&www.r129.co
