salihdeniz
- Nov 12, 2017
- 320CDI
Dear Members,
This is Salih from TURKEY.
Mercedes 2007 R320CDI(W251) 210000km.
After the car stays a night; I try to start in the morning; the engine cranks but it does not start at the first time.
Second start; the engine starts like it's brand new.
During the day; no problem and so much fun to drive.
What we tried till now;
- Bosch diagnosis programme ==> No fault
- Injectors leakage test ==> 2 of 6 injectors replaced and introduced
- 6 glow plugs ==> replaced (eve no sign or errors dtedted)
- Crank angle sensor ==> replaced
- Rail sensor ==> replaced
- High pressure fuel pump sensor ==> replaced
- High pressure pump ==> replaced
- battery ==> replaced
- cranking speed measured and compared with another CDI320 ==> perfect
- fuel filter ==> replaced
- no leakage observed
We' ve been working on the car for a month but our minds stopped!
All comments are highly appreciated.
Do you recommend to replace the low pressure pump in the fuel tank or to insert a check-valve on the line that is from the low pressure tank to the fuel filter?
Thanks in advance.
Salih DENİZ
Thanks in advance.
Salih DENİZ
