charlysays
- Jan 11, 2016
- Location
- Pembrokeshire
- Mercedes C250 Turbodiesel Sport Auto Estate
I replaced the springs on my 97' C250 TD this week... car was fine before.
New rear springs on and the first test drive it changes down into 4th when doing 60mph down a slight gradient and then doesn't want to go into 5th. I pull over, shift into N and back into D and it behaves itself for the rest of the drive.
Its done it a couple of times since now but seems to be getting less frequent.
I did the fluid, filter and O rings on the pilot bushing about 11k miles ago.
Checked the fluid again and it's a little overfilled (has been this way 11k miles) but I overfilled my previous C250 to a greater degree and it never played up.
When I did the fluid I'd run out of copper washers so reused the old ones and as a result the trans drain plug is dripping slightly so I'll sort this and drain off some fluid to get the level absolutely spot on. Will also check the multi plug isn't wet with ATF.
Anyone had this issue before?
Literally feels like the trans thinks its going down a steeper gradient than it is and the shifts themselves are normal.
