traffic0703
- Feb 26, 2008
- W205 C220d amg line premium 2017
Sorry to start a new thread off but the title of my existing one is wrong for this new development.
My car has been having gear selection issues and dealer tells me new box needed!
It would not change down using the throttle particularly if driving at a steady constant (which is the latest symptom.) If you accelerate from a constant speed the engine labours and it will not change down. It drives fine on paddles and it also drives fine if you stop - ie it takes 1st gear and then changes up through the gears no problem. Sometimes it will not take reverse when 1st started but if you go forward a little it then comes back to normal. Other than that, the box has no bad noises and is totally smooth running. It has recently gone a few weeks with no symptoms at all but the latest one of no down changes when accelerating did not seem to want to go away on ignition re set but only drove it a few times before dealer took it.
STAR shows code 0722 no output sensor signal available on the gearbox. This is a stored fault only. It has had a few checks by the dealer and mobilo.
STAR shows code can be erased and ignored.
Mercedes main dealer replaced electroplate 1 year ago so under warranty still. The car is with them at the moment with the intention of changing this under the warranty however:
They have examined the gearbox internally and tell me that there is excess play in one of the shafts which has the pickup on it causing the intermittent problem of no signal.
They tell me they now cannot do the electroplate under warranty as this is not the issue and it needs a new gearbox which writes the car off as not economic.
Full main dealer history on this car all up to date. Car has done 102,000 miles and gearbox oil changed by dealer at 37K and 95K when electroplate changed.
Has anyone come across this before? It is devastating news as the car has had a fortune spent on it keeping it exactly as it should be. I have no idea what to do from here.
