Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
any ideas what this noise could be.
Its particularly noticable on a cold morning start up.
As you drive off their is a slight rattle type noise from the engine as you accellerate. If you back off the throttle it becomes more noticable. If you gently start to accellerate it gets quieter.
After about 2 miles it disapears. And runs normally
Mileage is nearly 60,000.
Oil changed every 5,000 miles (Mobil1 0W40) until last change 9,000 miles ago ... slipped up there!
(but the wife insists their is a missing invoice).
Petrol consumption is normal, coolant level is normal, no milky crap.
I read up and it has one of those pumped type of timing chain tensioners. ( has oil holes you have to line up).
So I wondered if the seals were on the way out. Would that make it provide less tension, until the engine oil pressure had built up in it. And hence after a few miles its silent i.e. the tensioner is working properly?
Likewise if on start up the chain was a bit loose .. hence it rattles, especially when one backs off the throttle i.e. would that slacken the chainuntil you accellerate again.
Or does it not work like that?
Any clues what o look for appreciated, made more difficult as I hardly ever drive it ( maybe move it in the driveway once a year) so I am very unsure what it should sound like.
Wife needs the car for short journeys for the next week so difficult to get it to an Indy.
Advice appreciated ... if it is the timing chain tensioner, thats working but not perfectly ... would driving gently for say another 60 miles damage stuff , i.e. could the chain jump? Etc.
Its not lost any oil, and once the noise goes away drives like before.
Any ideas?
Any ideas?
