A150 not starting
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by ash1212002, Jan 12, 2018.
  1. ash1212002
    ash1212002 Senior Member
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    clk 200 coupe kompressor auto 57 plate
    Hi guys
    My father in law has a 2008 a class a150 petrol automatic which does not start. Lights on the dash appear, but when turning the key the engine does not start...
    Battery is fine
    Tried the spare key, still no joy
    Could this be a relay, starter motor or ignition issue?
    Any ideas?
  2. John Laidlaw
    John Laidlaw Senior Member
    17,635
    4,312
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    What happens- any cranking at all or just a ‘click’?
    ash1212002 likes this.
  3. bembo449
    bembo449 Senior Member
    2,666
    474
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    216 5.5 v8 , range rover vogue , 221 320cdi , alfa romeo brera
    as above , need more info really
  4. Arudge
    Arudge Senior Member
    753
    240
    Jun 14, 2016
    Cradley Heath
    Your Mercedes:
    CLK200 2000 Kompressor
    If the motor is turning but it's just not firing, then the crank position sensor is a possibility. Even a simple code reader should confirm.
  5. bembo449
    2,666
    474
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    this is the Peugeot engine ??
  6. OP
    ash1212002
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    It's not cranking over at all, it clicks
  7. GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    A200 Avantgarde Special Edition Sports Coupé • C169
    Does this fault appeared suddenly, or was the car doing that only when hot, initially?
    My A200 did that a couple of times, when [really] hot - took it to Terry at Wayne Gates to replace the starter motor.
    Brilliant job and no more errors.
  8. Cole@MBS
    Cole@MBS Forum Supporter Authorised Forum Supporter
    13,409
    407
    Dec 1, 2008
    Hedge End, Southampton
    Your Mercedes:
    124 300 CE 24 Coupe, 209 240 CLK
    Starter motor is a very common fault with 168 and 169.s..............
    ash1212002 and GLK like this.
  9. OP
    ash1212002
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    Is it difficult to replace? Any guide available? or guidance on how it can be done?
  10. OP
    ash1212002
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    Yesterday first thing, it wouldn't start but 5 mins later it started fine, does this still point to the starter motor?
    What did it cost if you don't mind me asking?
  11. John Laidlaw
    17,635
    4,312
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Starter motor I guess around £300 and labour 3 hours ( about right Colin?)
    Are you sure the battery is ok by the way?
  12. OP
    ash1212002
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    Yep battery is definitely fine.
  13. Arudge
    753
    240
    Jun 14, 2016
    Cradley Heath
    Your Mercedes:
    Easy way to test the battery is put the headlights on, and turn the ignition key to start. If the headlights go dim the battery is knackered.
  14. GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Not the same pattern as mine was - it refused to start after a long [fast] drive, and I had to wait, with an open bonnet, for the engine to cool a little bit, to get it started again. At least I had a full tank LOL
    The OEM starter motor is as mentioned above, plus the labour cost ...
    As far as I know, there is one other possible reason - a CVT fault, which is far more serious, than a starter replacement.
    There's a guide on Forrera facebook page as to how to do a test, to determine which one it is (power directly to the starter - again, if I'm not mistaken - a simple 'such-and-such wire to touch a positive terminal'.
  15. OP
    ash1212002
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    Rac have come out to recover vehicle and determined it is the starter motor
    Any online guide/advice on how to replace? Is it easily accessible?
  16. John Laidlaw
    17,635
    4,312
    Nov 15, 2013
    Wirral
    Your Mercedes:
    In a word no- you’ll need a ramp and in that model the engine and sub frame need dropped to gain access.
    Not an easy fix. I think I probably underestimated above too probably nearer 4 hours than 3. Sorry.
  17. OP
    ash1212002
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    There's a short youtube video and bert Rowe's guidance re the job, apparently it can be done without dropping the engine and sub frame, nevertheless its still a time consuming tedious job as the starter motor is in such an awkward location!
  18. John Laidlaw
    17,635
    4,312
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Yes, I heard about that but haven’t seen it, must have a look sometime. Thinking of having a go or indy route?
  19. OP
    ash1212002
    180
    6
    Aug 9, 2015
    Coventry
    Your Mercedes:
    I think it'll have to be the indy route! as he doesn't live close by, otherwise would have given it a go.
    It also appears that there's variants of the starter motor and there could be a risk that the wrong type of starter could be purchased even if purchased via merc!
    So i think it would be best to take the old one out first otherwise you could end up having to do the job twice!
  20. John Laidlaw
    17,635
    4,312
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Don’t blame you- think I’m getting too old and lazy for that nonsense these days!
Share This Page
