forrera
- Dec 4, 2017
- several W168, W169 and W245s
A quick test to determine if it is the starter or not.
There's a small plug near the battery positive terminal with 2 or 3 wires. One of them has a purple trace, this one goes directly to the starter solenoid. Attach your test light or meter to that wire and crank the engine, if you get 12v while cranking then your starter is faulty.
Not the easiest job to do. You'll need to remove both rear engine mounts and lower the back of the engine.
