A180 rear light cluster
Phillip Booth
Registered
A180 CDI/2014/
Was hoping to get some advice if possible.
My wife brought our 2014 A180 CDI home earlier today and it appears the driver side brake light has failed.
I removed the light cluster and lamp holder only to find that it seemed impossible to remove the faulty bulb from the holder and replace myself(appears I can only remove the indicator bulb).
First off am I being a moron? It seems that all the bulbs other than the indicator are fixed to the holder and not meant to be removed.
Is this the case or is their a certain nack to removing them?
Thanks in Advance
Phil
joderest
ML270 2003
I am sure someone will be along soon to correct me.
BUT
are the rear lamp and stop lamp LED ? If so, you may have another fault.
If they are led, you may have to replace whole assembly
