[Spares] Adaptive Brake Light System
Discussion in 'Spares for Sale and Wanted' started by GLK, Jul 9, 2018.
Thread Status:
Not open for further replies.
  1. GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    A200 Avantgarde Special Edition Sports Coupé • C169
    Bahamas 45th Independence Day Special :) Only £29 delivered.
    I've had no failed units so far, so I decided to keep only six PCBs in reserve for warranty purposes, and assemble the remaining units, so I have an even dozen now - there won't be any more manufactured.
    This is a private sale, however one year warranty will be honoured regardless.
    The system is aimed at older vehicles, obviously.
    Adaptive Brake Light System by Keep Ness Robotics
    An adaptive brake light system, is fully independent of the vehicle's computer system. In fact, the idea was to be able to fit it to a 30-yr car, and that's what's been achieved.
    The system will know not only when you brake hard, but also the direction of travel, which is its unique feature - and will alert the other road users to the emergency braking, just like the factory-built adaptive brake light systems in the latest models.
    Unlike those cheap Chinese strobe units, it is legal and fully compliant with the current regulations, as it will only flash, when rapid deceleration in primary direction is detected, and will not fail you an MOT.
    The system can be retrofitted into almost any car, and is small enough to be fitted inside a tailgate trim, or a boot lid, etc. A simple DIY installation is all that's required - the unit sits between your existing [third] brake light, and the signal wire from either the SAM, or the brake sensor in older cars. The only additional requirement is an 'ignition on' 12V feed.
    It can also be fitted to flash all brake lights, but please check with me first, and consult your manual as to the wattage of your light bulbs, particularly for cars over 30 years old.
    The unit will be supplied with a top of the range, genuine 3M Dual-Lock mounting pads, and a high density, closed cell, anti-vibration pad, to ensure the best possible fitting and prevent it becoming dislodged over time.
    It can be mounted in any position, at any angle, etc.
    If a DIY install is not something you're comfortable with, a professional should be able to fit the unit in 10-15 minutes tops, so shouldn't be too expensive.
    The installation guide is below. Please contact me, should you have any questions.
    Please note:
    The deceleration threshold is set to 0.5G.
    This corresponds to the UK Highway Code's definition of emergency braking for passenger cars, i.e. 60mph to full stop in 240yd or 73m.
    It is not possible to change it.
    This deceleration rate (
    0.5G = 4.9 m/s2 = 5.36yd/s2 ) might be too high for motorbikes, given the significant difference in weight and driving patterns.
    [​IMG]
    [​IMG]
  2. LostKiwi
    LostKiwi Senior Member
    15,067
    6,111
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    I'll have another David.
    GLK likes this.
  3. V6Matty
    V6Matty Senior Member
    5,410
    479
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    S212/10/E350(His) W169/2005/A180 (Hers)
    I'll take one David, the wife's 169 would be a perfect home for one
    GLK likes this.
  4. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Oh, great! Thanks chaps! :)
    I'll get them posted tomorrow.
  5. LostKiwi
    15,067
    6,111
    Aug 25, 2006
    Your Mercedes:
    Hang on to mine David as I'll be in France. Once I'm back we can meet up and do the necessary.
    GLK likes this.
  6. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Of course, will do.
  7. Alex Green
    Alex Green Senior Member
    85
    24
    Jul 5, 2017
    Your Mercedes:
    Cl500/2000/V8 5.0L
    I'm a bit late to this party but could I get two units please?
    Cheers
    Alex
    GLK likes this.
  8. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Certainly, thanks Alex!
    I'll PM you right away :)
  9. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    I still have 7 units available, the offer still stands - £29 delivered.
    Comes with anti-vibration foam mounting pad, and 3M Dual-Lock strips, plus a spare.
    Can be fixed in any position / direction.
  10. EXMERCTECH
    EXMERCTECH Senior Member
    132
    16
    Aug 7, 2003
    Sutton,Surrey.
    Your Mercedes:
    C320 V6 Diesel 2005
    I'll take another for my 1979 Scimitar.
    What resistors would I need for the Merc 3 brake light set up?.
    PM me your payment details.
    Phill.
    GLK likes this.
  11. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Fantastic, thanks Phill!
    I just sent you a PM with all the details, and resistors link :)
    Kind regards,
    David
  12. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Still have a few left ;)
  13. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Still have a couple of units left :)
    Still only £29 delivered
  14. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Another 10% off - £26 delivered.
    This is now well below the manufacturing cost, just want to clear these off, and close this chapter ...
  15. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Still available :)
  16. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Still only £26 including delivery ...
  17. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Still have a couple of these :)
  18. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
  19. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Still have a couple left ...
  20. OP
    GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Halloween & Birthday Weekend Special ;)
    Last two remaining units - £25 each delivered.
    PM or email: david.glk@mail DOT com
Thread Status:
Share This Page
