diblack
New Registration
Hello,
I need to find out how much transmission fluid needs to be put into A170, 2001, 1.7 CDi - transmission model 423 (5 speed manual).
Long story Short: My car was serviced in MB authorized service, and started to act up. Eventually, after two more visits in MB service, I decided to go to unauthorized, but well known Automatic transmission specialist. His verdict is scary - When MB was changing transmission fluid, they supposedly poured in less oil than is needed. According to the invoice from MB service place, they poured in 3 liters. However he claims that there should be 5,5 liters poured in during the change. This checks out with the sources I was able to find online, but I want to double check with someone more experienced, since I am no mechanic. As a result some of the bearings in the transmission got damaged and approximate cost of repair is 1000 pounds.
Please, can someone advice me, how much oil needs to be put into the transmission when being changed? Thank you
