Advice please mercedes s 320 se December 2005.
Discussion in 'General Mercedes-Benz Related Discussion' started by mercmancdi, Nov 7, 2018.
  1. AMGeed
    AMGeed Senior Member
    4,703
    954
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2004 W211 E55K ///AMG
    You can check whether the car raises and lowers using the button by the gear shifter. If its like my airmatic (totally trouble free in over 5 years incidentally) both red lights showing is the lowest setting, one light slightly higher, no light is the highest setting.
    Take a look when you first arrive to see if it is sitting evenly and not lower/higher on one or more corners. The airmatic pump should raise the car silently. Undue noise may point to a tired pump.
    As John above, airmatic is arelatively simple and mainly trouble free system. I'd take it over ABC anyday simply over the cost if either goes wrong.
    mercmancdi likes this.
  2. OP
    mercmancdi
    mercmancdi Senior Member
    1,729
    107
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    I know the cars been sitting a few days and it was sitting nice and square , the only noise I heard was when I turned the knob for lumbar
    in the seats. It seemed to be a button at top centre of dash when
    Pushed lit 2 red lights and brought up screen menu.
  3. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    Thanks going back tomorrow for second look
    McDonald likes this.
  4. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
  5. John Laidlaw
    John Laidlaw Senior Member
    16,556
    3,847
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
  6. Naraic
    Naraic Moderator
    9,840
    621
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Seems a reasonable price too for those miles.
  7. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    Only thing it’s well loaded and very tidy but no heated seats , also when
    I push button on dash it’s comes up on centre screen sport 1 ,then push again sport 2 ,then push again convenience comes up. Should I feel the suspension move . Or how does this operate.
  8. LostKiwi
    LostKiwi Senior Member
    14,181
    5,506
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Nuclear physics is simple compared to ABC...
    Capra, Blobcat and John Laidlaw like this.
  9. LostKiwi
    14,181
    5,506
    Aug 25, 2006
    Your Mercedes:
    Air suspension is much the same as the Citroen system in principle, it just has electronic control.
    Fundamentally its a compressor, a reservoir or two, a couple of valve blocks, airbags on each corner and height sensors.
    The pump provides air to the reservoirs, the height sensors tell the computer what it needs to do, the computer tells the valve blocks to open or close and the valve blocks let air in or out of the bags as required.
    In terms of issues, pumps can fail, relay operating the pump can fail, sensors can fail and bags can fail. The pipework to the bags can corrode (especially at the rear).
  10. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    I push button on dash it’s comes up on centre screen sport 1 then push again sport 2 then push again convenience comes up. Should I feel the suspension rise when switching this.
  11. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    This is the spec . Apart from heated seats is this about normal or below par for a reg dec 05 s class 320.
    WDB2200252A480488 www.DataMB.com 1
    2005 MERCEDES-BENZ S 320 CDI (220.025)
    General Data
    FIN
    Model
    Engine Transmission Order Number Order Location Interior
    Paint 1 Release Date Delivery Date
    WDB2200252A480488 S 320 CDI
    648960 30 128533 722626 06 111599
    0 5 537 93126
    GREAT BRITAIN
    LEATHER ANTHRACITE (271A)
    BLUE QUARTZ METALLIC PAINT (347U) 2005-06-09
    2005-06-09
    Code Description
    205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH 220 PARKTRONIC SYSTEM (PTS)
    221B SIGN COOLANT/REFUELING - ENGLISH
    249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING 250B MOBILO LIFE/EUROPE SERVICE PACKAGE
    260 TYPE DESTINATION ON TRUNK LID - ELIMINATION 270A LEATHER
    271A LEATHER ANTHRACITE
    283B AIRBAGLABLE - ENGLISH
    347U BLUE QUARTZ METALLIC PAINT
    354 ANTENNA FOR TELEPHONE D/E-NET
    386 MOBILE PRE.-INSTALLATION (MTUS)
    414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
    461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
    474 PARTICLE FILTER
    527 COMAND DVD APS WITH NAVIGATION
    537L GREAT BRITAIN
    551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
    5XXL EUROPE
    600 HEADLAMPS - CLEANING EQUIPMENT
    608 LA 5 HOLE HOLLOW SPOKE WHEEL W/ MIX. TIRES
    613 HEADLAMP LEFT-HAND TRAFFIC
    666 PACKAGING FOR SHIPPING VEHICLES W/O TIE-DOWN HOOKS
    673 HIGH-CAPACITY BATTERY
    731 WOOD TRIM BURRED WALNUT ROOT
    805 CHANGE OF MODEL YEAR, THE LAST FIGURE SHOWING THE NEW MODEL YEAR 819 CD CHANGER
    875 HEATED SCREEN WASH SYSTEM
    882 INTERIOR SAFEGUARD
    926 EXHAUST GAS CLEANING WITH EU4 TECHNOLOGY (EURO 4)
    983 COC PAPER EU4 TECHN. + NO VEH. TITLE OF OWNERSHIP
    989 IDENTIFICATION LABEL UNDER WINDSHIELD
    K11 ADAPTIVE STOP LIGHT FLASHING
    M002 ENGINES WITH EXH.TURBOCHARGER WITH INTERCOOLER
    https://www.datamb.com/vin/rjKDXd4ObW8ApN38B
    WDB2200252A480488 www.DataMB.com 2
    Code Description
    M32 CAPACITY 3,2 LITER
    M648 R6-DIESEL ENGINE OM648
  12. John Laidlaw
    16,556
    3,847
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Not seeing anything on the data sheet about airmatic/airbags?
  13. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    What’s that mean , good bad etc .
    Vin is.
    WDB2200252A480488
  14. SL55 Mark
    SL55 Mark Senior Member
    2,268
    75
    Oct 1, 2012
    South
    Your Mercedes:
    2004 SL55 AMG
    Maybe it doesn't have airmatic, especially if you can't find the raise/lower buttons
    It does look a nice car, they have a certain "presence", and set the standard for ride quality in their day.
  15. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    There’s a button on left of gear lever with lights and 3 strokes at it and a button at top middle of dash which brings up the sports 1 & 2 and convenience writing on the dial
    Problem is the guy selling it doesn’t know
    much about them either.
    It’s just he took it in .
  16. Naraic
    Naraic Moderator
    9,840
    621
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    I have ABC and the button which raises and lowers the suspension does just that.
    Well specced? Doesn't have ventilated massaging seats nor bi xenon.
  17. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    Thanks , how do you operate it , when on display should you be able to scroll through the option.
  18. Naraic
    Naraic Moderator
    9,840
    621
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    In my car there is no display for the abc height settings or sport setting.
  19. OP
    mercmancdi
    1,729
    107
    Dec 6, 2011
    Your Mercedes:
    Strange I can bring up sport 1 sport 2
    Or convenience
  20. Naraic
    Naraic Moderator
    9,840
    621
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Could be other settings. But does suggest airmatic.
    With the weather it is the way it is Glengormley's a bit too far to go and see it.
Share This Page
