Air Con will not start, 2008 220CDI Elegance
Discussion in 'General Mercedes-Benz Related Discussion' started by Robbo57, May 16, 2018.
  1. Robbo57
    Robbo57 New Member
    May 16, 2018
    Your Mercedes:
    2008 C series 220D Elegance
    AC will not cool, when button is depressed the integral light flashes once.
  2. EmilysDad
    EmilysDad Senior Member
    6,211
    623
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    Is there any gas in the system? Condensers have a habit of rotting at the bottom due to salt from the road resulting in loss of gas.
  3. Flyinspanner
    Flyinspanner Senior Member
    1,428
    282
    Aug 8, 2010
    Ruislip
    Your Mercedes:
    CL500 -W215, A140-W168
    It may be low pressure. (Stone hit condenser?)
    Need pressure test, or checking over with a UV lamp if you’ve had dye added at last recharge, any area where leaks will light up.
Share This Page
