AMG alloys on 2002 SLK Kompressor
Discussion in 'AMG' started by chrisfriel, Jun 1, 2018.
  1. chrisfriel
    chrisfriel New Member
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    Will 18" AMG monoblock alloys fit on a 2002 Merc SLK Kompressor and if yes, any idea what tyre size should you use?
  2. AMGeed
    AMGeed Senior Member
    4,797
    1,020
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2004 W211 E55K ///AMG
    I don't think you'll find any suitable monoblock wheels with the correct radius boltholes for M12 bolts your SLK needs.
    The CLK monoblocks are M14 boltholes with the correct offset
    The CL and S class monoblocks are M14 boltholes with the wrong offset.
    If you find some monoblocks, post up the Part number and ET which are both inscribed on the inside of the wheels and you'll get a definitive answer.
  3. OP
    chrisfriel
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    Hey there, thanks for replying. The part numbers on the ones i have are:
    HWA 129 401 01 02 ET 31
    HWA 210 401 02 02 ET 35
    Are these the numbers you mean?
  4. AMGeed
    4,797
    1,020
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    If genuine AMG monoblocks they should begin with some thing like
    A208........ or A220......
    The only numbers above I recognise are 129 and 210 which are SL and E class wheels?
    The ET looks to be OK which is important. The bolt holes even more so, although I believe you can buy M12 (12mm dia thread) radius head bolts with an M14 head
  5. OP
    chrisfriel
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    Don't know if these pictures are any use to establish what they are?
  6. AMGeed
    4,797
    1,020
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
  7. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    W202 or W203 Monoblocks will go straight on but they are incredibly rare
    There were many replicas made by a company in Italy called Invicta, they were superb quality and took an OEM MB wheel centre, you may have more luck with them
    Tyre wise
    225/45 R17 front and 245/40 R17 rear
    225/40 R18 front and 245/35 R18 rear is correct
    AMGeed likes this.
  8. OP
    chrisfriel
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    Im not very clued up on this and have possibly shot myself in the foot (hence me looking for advice from you guys that have the knowledge) but ive already bought the alloys i mention above, and paid for them to be refurbed, so im really hoping that these will go on my merc SLK.
    Ive been told they should fit, possibly i may need low profile tyres because the back wheels may catch the wheel arch as they are bigger.
    Any and all advice is welcome cheers
  9. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    Need to know the sizes, they should be stamped on the inside of one of the spokes
  10. OP
    chrisfriel
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    Can you see the pics above in this thread? Attached them again in case
  11. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    8x18 ET31, are they the same all round?
    Missed the pics before :confused:
  12. OP
    chrisfriel
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    No, staggered.
    All 18” but back is wider. Pics above are one of front of alloy and the other two are one of each front and back.
  13. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    Rear is a 9x18"
    Test fit them
    You should go back to the refurbishers, they have painted the mounting face (where the bolt holes are), you should never do that
  14. OP
    chrisfriel
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    All holes still there? Apols if I’ve misunderstood...
    Need a bit of help???
  15. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    On the inside of the wheel where the bolt holes are, they have painted it, it needs sanding off, you need that surface completely smooth
    Here
    Also why is there a spigot ring in the centre bore?????
    Those wheels are off a Merc 129 series car
  16. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    To clarify
    In Red is the part number
    In Blue is the wheel size
    In Orange is the ET (Offset)
    In Green is a Spigot Ring which shouldn't be there
    You also need to check the bolt hole sizes, your car takes a 12mm bolt
  17. OP
    chrisfriel
    8
    Jun 1, 2018
    Your Mercedes:
    SLK Kompressor 2002
    That inner circle isn’t flat...there’s a slight indent where it’s a bit lighter in colour?
    I guess that can be sanded down easily enough?
    Do you think these tyre sizes will fit? Spent a bit on them so I’m really hoping so:
  18. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    Give it a pull, should come out, I think they have been fitted to a VW in the past
    Yup
    Correct
Share This Page
