Uncle Benz
- Mar 31, 2006
- Age
- 53
- Location
- West Sussex
- Mainly Mercedes
I didn't get a picture today sadly. A 2006 CLS, complete brake failure. Metal pipe on the offside to the rear caliper, rotted right through. Typically it was completely hidden by the plastic plank running down the floor of the car, so could never have been picked up on an MoT test. The pipes have some little rubber sleeves to prevent rubbing, but these seem to be the culprit, holding moisture between them and the pipe, and rotting away. The owner was shocked at the level of pedal effort required when the SBC system goes offline. Yes, it is quite a surprise Sir!
Anyway, new pipe made and fitted, system bled and pressure maintained via Star for five minutes to check for leaks. Monday I'm going to pull the under tray off the other side to see the condition of the pipe there. If it look suspect I'll replace that one too. I will get a pic or two Monday for you.
