ASR defeat is it possible and keep ABS?
XJguy
NY, USA
94 E320 coupe
ASR defeat in 94 E320. I just had an idea, if I were to provide a constant voltage to the wire that sends the throttle position location signal to the ASR computer, the car won't know its accelerating, this might be enough to fool the ASR while still keeping the ABS fully functional.
Craiglxviii
Cambs UK
Why would you want to?
Westheath
South London
Edit see below
Parts I've changed/repaired over the years related to BAS ASR ABS problems.
Wiring (connectors)
Brake light switch
ABS sensors/reluctors
Brakes sticking/seized caliper/s
ABS pump
Throttle body (wiring)
Make sure you have a diagnosis session done to identify and remedy the fault.
I think it's working but he wants to be able to disable it (for doing donuts?).
Westheath
South London
I recommend this then..............
XJguy
XJguy
NY, USA
94 E320 coupe
I have a twin turbo system, the ASR system kills the power at launch. 500e and w202, as well as sl320 uses different easily defeatable ASR system; e320 is not.
Westheath
South London
Does the ASR switch mod not work then, fitting a ASR switch to turn it on/off ?
Tutorial here > http://www.2phast.com/500e/
XJguy
XJguy
NY, USA
94 E320 coupe
No it won't.
www.W140.co.uk&www.r129.co
