ASSYST Reset
toxic
this may work on other cars 95>98.
1 Turn electronic key in the steering lock position 2
2 Within 4 seconds, press button "O" twice
3 Note! The present status for days or distance is displayed.
Within 10 seconds, turn electronic key in steering lock to position 0
4 Press and hold down "O", while turning electronic key in steering lock to position 2. The present status for days or distances is displayed once more. Keep holding down button"O"
Note! After approx. 12 seconds a signal beep sounds and the display will show 10,000 miles or 15 000 km for other countries
5 Release button "O"
regards Mark
The procedure to reset the ASSYST is listed in some owners manuals and also here in PDF format.
dava
The Toon
To reset the service light (spanner) on 2000-07 Sprinters.
Switch on ignition
Press KM button twice
Switch off igntion
Press and hold KM button
Switch on ignition and hold untill spanner resets and bleeps.
It is advisable to have all doors shut as sometimes it gets a feed from the curtesy light, ie, when you open the drivers door the speedo lights up.
2007 onwards is different and more complexed I will post later.
PS can some one make this sticky?
Hope it helps
Ray
If you wish to discuss this thread pls post replies here
