Simon21
- Mar 19, 2011
- 1988 W124 250TD
I had a ball joint fail on my 88 W124 250TD - luckily at 5 mph. I immediately had the other one done. What the MoT man (and the RAC garage that did the first ball joint) didn't spot was that both front springs were broken about 4" round the coil from the base.
While you have the front end in bits, check the bleed nipples on the calipers. Murphy's law says they'll be heavily corroded, and you might also take a look at the bushes on the lower arm. They can be replaced with a kit from GSF.
