B Class CDi BlueEfficiency wheels/tyres
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by copydeskcat, Jul 10, 2018.
  1. copydeskcat
    copydeskcat Member
    17
    Apr 20, 2014
    Your Mercedes:
    a180 cdi 2010 platge
    hi guys,
    Silly question - so please excuse my ignorance...
    I have a B Class CDi BlueEfficiency with the low profile tyres and alloys.
    I’m a bit sick of feeling every single bump in the road with the wheels/tyres, and wondered what my options are to replace them.
    For example, can I just switch out the wheels for standard wheels and bulkier tyres, or is this car not really suited to these type of wheels/tyres?
    I’m just trying to figure out how much it’s going to cost, if I decide to go for it.
    Any advice would be much appreciated.
    Best,
    CDC
  2. ernieh
    ernieh Senior Member
    1,345
    37
    Nov 20, 2006
    Scotland, East
    Your Mercedes:
    205 / 67 / C220 d
    Check your handbook for the options that are fitted to lesser models than yours. You don't say which is your trim level, but for example, if yours is a Sport, then SE wheels and the correct tyres would give you a more comfortable ride. The other thing to check is if you are on Runflats; standard tyres of the same size would be smoother.
    Just be careful, though, if yours is an AMG with I think, 18inch wheels, the 16s from an SE won't fit over the AMG discs and calipers and possibly neither will the 17s from a Sport!
    Somebody who knows the B Class better might be able to give you more specific info for it.
    Ernie
  3. Blobcat
    Blobcat Moderator
    8,451
    206
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    W213 E220d, Smart R451 CDI, Porsche 911 C2S, Land Rover 110 County SW
    Inside the fuel filler car will most likely be a list of the tyre size options and the tyre pressures. Go down rim size and up sidewall ratio if the option is available. I went from 18" to 16" on my W210 and it was so much better because of it.
  4. Wighty
    Wighty Senior Member
    3,852
    1,495
    Aug 4, 2016
    Your Mercedes:
    If you have a spare wheel , that is probably the minimum size you could go to .
  5. OP
    copydeskcat
    copydeskcat Member
    17
    Apr 20, 2014
    Your Mercedes:
    Brilliant. Thanks guys. I’ll have a look at it.
Share This Page
