gilesbracher
- Nov 15, 2017
- S211, E Class Estate, 2006, 280CDI ( Previously: W116, 1977, 280SE )
I have just got back to my new to me S211 having been away for a month, to a totally dead battery! (Battery 6 months old) No clicks, flickers, anything, dead as a post. Only Manual door lock working.
I think have traced the drain down to an after market fuse in the boot, under where the Nav DVD is. When I remove this fuse the ammeter drops down to 0.01amp from an average 0.14amp. I have read that 0.01 is normal?
I think this fuse (see pic) is connected to a Dolphin DT0035 CAN-Bus interface. I am guessing this was used to add a phone to the car at some point.
http://www.sanostore.top/altro-cavi...nbus-interface-per-mercedesbenz-p-4931.xhtml?
So far disconnecting this fuse has not affected any functionality of the Command, though I don’t have a phone connected as yet.
Out of a matter of curiosity there are several coils of wire (wild knitting when I got the car) that appear to be aftermarket. See attached photo
Loop 1 comes from another black box on top of the Drive Rack with a GPS SIM label on it. And goes up the corner strut of the car. See photo below.
Loop 2 also come from the GPS SIM box but is some how connected with a wire that has a red LED in the end the still blinks every few seconds.
I have been wondering if there is some kind of alarm / immobiliser? When I use the key fob to lock the car the hazard lights flash twice. But if I open the door using the manual key there is no alarm sound, as I have read there would normally be? (Battery providing of course)
Thank you to any one who can shed some light.
1. Is there any feed back out there on what normal drain on a battery parked up should be?
2. How long is it reasonably safe to leave a 2006 E class parked up (0.01amp draw) with out effecting starting (assuming a charged good battery)?
3. Can any one tell me for sure what this box does and if it will effect anything now I have taken the fuse out?
4. Can any one suggest what they might be? See the picture.
Aftermarket Wiring & Fuse
Any suggestions what these loops of wire are for, and what the fuse is protecting?
