gramey
- Jul 23, 2016
- Location
- Ipswich, Suffolk
- Currently none
I have a slight problem with my newly acquired R230 SL350 in so much as something is draining the consumer battery. I believe it to be the Comand unit as despite the engine being switched off there is a fan or something whirring away behind this even after you've locked the car and left it for an hour or more.
I've have tried desperately searching the internet, this forum included, trying to find a way to shut this down but so far with no success. I pulled what I believe were fuses 57 & 77 which should cut it off, but with no apparent numbering on the fuses it may have been the wrong ones. That said I pulled a few of the others as well, but that didn't work and I didn't want to pull the high amp ones in case I did any damage.
I'm sure someone else has suffered this, there seem to be several posts relating to battery drain on R230's, but can anyone who has please tell me exactly where to find the correct fuse/fuses to shut it down?
The car is booked in for a diagnostic check but they can't look at it for a week so if there's a simple fix, as in cutting the power as you do with your Sky box, I would love to know.
