Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
OK in an attempt to get rid of brake squeal I changed the front pads.
I have driven around now for 730 miles with very gentle braking. Avoiding holding the brakes on after Braking for say 300 miles; and since then just pretty tame/moderate braking.
So is it time to use a bedding in process?
Partly spurred on due to feeling very slight brake judder, braking down from high speed. But it could have been the M4s poor surface, as not noticed it before or since changing the pads. (I also need to re-torque the bolts as I set them to 140 Nm and the locking bolt to 130 Nm not the 150 Nm in the manual.)
Wow what a lot of conflicting advice, ranging from:-
- 3 moderate stops from 30mph to 15mph, and then 3 fairly hard stops from 60 mph to 10mph
To
- 20 stops from high speed (100mph) to 15 mph.
The only consistency in these advisory practices is
- dont stop completely
- always imediately get back up to speed to cool them off for 3 mins to 1 mile (again conflicting advice)
- never sit with your foot on the brake after a stop, where the pad is in contact with the disk.
As I have Brembo front calipers, I looked on their site. Ironically the only thing I could see was
"A brief running-in period is always needed
Brake discs and brake pads are the heart of the braking system and their perfect working efficiency is reflected in the active safety of the vehicle. However, a brief period of running-in is needed (approximately 300 km) from when the brake discs and brake pads are replaced. During this period, the driver should make brief, soft braking movements to allow the surfaces of the brake pads in contact with the brake discs to align correctly. A poor running-in period could cause the components to wear down irregularly and compromise the performance of the braking system."
Note no suggestion of Pad material transfer or any kind of hard braking!
On the other hand I did see this advice, which seemed to have a fair bit of logic.
"How to Bed in Brakes
After the first break in cycle shown above, the brakes may still not be fully broken in. A second bed-in cycle, AFTER the brakes have cooled down fully from the first cycle, may be necessary before the brakes really start to perform well. This is especially true if you have installed new pads on old rotors, since the pads need some usage to conform to the rotor wear pattern. If you've just installed a big brake kit, pedal travel may not feel as firm as you expected. After the second bedding cycle, the pedal will become noticeably firmer. If necessary, bleed the brakes to improve pedal firmness"
So in summary for my new pads and old rotors, thats 8-10 hard stops from 60-20mph. Cooled in between, then a long cool down and an additional 8-10 hard stops from 60-20mph.
Obviously gently warming the brake rotors first, never coming to a stop, or activating ABS lockup, and cooling them down between stops.
With hindsight I do wish I had changed the front rotors, as I may keep the car another year ( yeah like it that much )
To
- From 60mph, gently apply the brakes a couple of times to bring them up to operating temperature. This prevents you from thermally shocking the rotors and pads in the next steps.
- Make eight to ten near-stops from 60mph to about 20 mph. Do it HARD by pressing the brakes firmly, but do not lock the wheels or engage ABS. At the end of each slowdown, immediately accelerate back to 60mph, then apply the brakes again. DO NOT COME TO A COMPLETE STOP! If you stop completely, with your foot on the brake pedal, pad material will be imprinted onto the hot rotors, which could lead to vibration and uneven braking.
- The brakes may begin to fade after the 7th or 8th near-stop. This fade will stabilize, but not completely go away until the brakes have fully cooled. A strong smell from the brakes, and even some smoke, is normal.
- After the last near-stop, accelerate back up to speed and cruise for a few minutes, using the brakes as little as possible to allow them to cool down. Try not to become trapped in traffic or come to a complete stop while the brakes are still hot.
- If full race pads, are being used, add four near-stops from 80 to 20 mph.
