Bleedin Brakes
Discussion in 'Suspension, Steering & Brakes' started by tedfred, Oct 10, 2018.
  1. tedfred
    tedfred Senior Member
    112
    29
    Apr 29, 2018
    Your Mercedes:
    slk 200
    Hi All,
    Does anyone have any experience of using any of the DIY Auto Brake Bleeding kits? I intend to change the fluid in the SLK200 before the winter and thought for once I would try and do it the supposedly easy way.
    Can anyone recommend a brand??
    Thanks for your time
    Regards
    Tedfred
  2. LostKiwi
    LostKiwi Senior Member
    13,797
    5,216
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    If you have a pump for doing oil changes attach to a brake bleed nipple and do it that way.
    Otherwise I've used a Gunsons one and it worked ok. Just a faff setting up an air supply.
    AnthonyUK and tedfred like this.
  3. Oldspanners
    Oldspanners Senior Member
    237
    127
    Oct 30, 2017
    Your Mercedes:
    C CLASS 2004 C180
    [​IMG]
    I've used this successfully to change brake fluid a few times with no problems, it just sucks in a little air around the bleed nipple but that's outside the system so you can ignore that.
    Quick clean and you can see the fluid change colour as it enters the holding bottle. It also can be used as a vacuum tester for about £14 on ebay you can't go wrong.
    tedfred likes this.
  4. Wighty
    Wighty Senior Member
    4,041
    1,627
    Aug 4, 2016
    Your Mercedes:
    I have a Sealey VS something I think , it's one of the pressurised containers that you attach to the brake fluid reservoir and then fill with brake fluid . It worked very well . You just open each bleed nipple and wait until it runs clear . I'm not at home otherwise I could check the make and model
    tedfred likes this.
  5. Wighty
    4,041
    1,627
    Aug 4, 2016
    Your Mercedes:
    Sealey VS820, £40 ish . Just checked it on tinternet
    GLK likes this.
  6. GLK
    GLK Senior Member
    2,917
    903
    Sep 19, 2014
    Northampton
    Your Mercedes:
    A200 Avantgarde Special Edition Sports Coupé • C169
    Interesting ... haven't considered brake fluid as a possible DIY before, incidentally Herr ESS is telling me it's due soonish ... hmmm
  7. mercmancdi
    mercmancdi Senior Member
    1,613
    70
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    To do it properly you would have to do every wheel. Wouldn’t you ?
    You could put a pipe on each nipple
    One at time and into bottle with fluid
    in it ,then pump peddle keeping the fluid topped up as you went working your way around each wheel , this would change the fluid wouldn’t it ?
  8. EmilysDad
    EmilysDad Senior Member
    6,297
    663
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    Yes, you need to do each wheel .... an order is usually given somewhere, though in practice it doesn't really make much difference.
    You do pump the pedal, but you need a glamorous assistant to open & close the nipple each pump of the pedal ie open the nipple as the pedal is pressed & closed as the pedal is slowly raised.
    It'll change most of the fluid, but the stuff in the ABS block will stay where it is unless you have the means to cycle the ABS pump.
    mercmancdi likes this.
  9. mercmancdi
    1,613
    70
    Dec 6, 2011
    Your Mercedes:
    If working with a bottle 1/2 full of fluid and ensure your pipe stays below fluid level in the bottle you would just open nipple and go pump peddle until you pump enough out without emptying the reservoir.
  10. umblecumbuz
    umblecumbuz Senior Member
    3,101
    522
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    As Wighty. I have the same unit. I bought it when my Esp unit kept giving trouble and had to be repeatedly removed for repair. It's so easy to use, and gives a totally reliable brake fluid change and bleed. The only hiccup I initially had was making sure I got a good seal when making connection to the reservoir, but I soon got the hang of it.
    Wighty likes this.
  11. EmilysDad
    6,297
    663
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    I wouldn't. There's a chance that air will suck up past the nipple, best to close the nipple before each upward stroke off the pedal. Easibleed or vacuum pump (or Pela oil extract kit) is also another way
  12. Uncle Benz
    Uncle Benz Senior Member
    2,182
    303
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    Personally I would avoid pumping the pedal methods. You run the risk of pushing the master cylinder seals into the end of the cylinder where they never go in normal operation. If there is a lot of debris/dirt/rust down there you can damage the seals and leave yourself requiring a new master cylinder. As a professional motor engineer I recommend a vacuum based system for changing the brake fluid. I have been doing it this way for over twenty five years, and I've never had a problem. I must do five or six a week!
    AnthonyUK and daibevan like this.
  13. OP
    tedfred
    112
    29
    Apr 29, 2018
    Your Mercedes:
    slk 200
    Thanks for all your replies Guys.
    I have question regarding using the Pela oil remover thought. Surely applying a Vacuum to each bleed nipple will not remove any fluid as the master cylinder would not allow the fluid to drain from the reservoir, you must surely have to partially depress the brake in order to allow a free path for the fluid to pass from the reservoir to the vacuum vessel?
    What am I missing here?
    I particularly like the vacuum method as I have just bought a pela 6000 today as suggested by LostKiwi in a previous thread.
    Thanks again for your time.
    Regards Tedfred
  14. mercmancdi
    1,613
    70
    Dec 6, 2011
    Your Mercedes:
    I think it’s down to knowing how much to pump befor toppping , I have done this for 30 yrs and never had a problem with master cylinder or drawing air in at the nipple , people open the nipple too far or don’t use correct pipe , it’s about just a few 1/2 pumps
    And top up it’s no time till the new fluid is running nice and clean , then move on to next , the whole system holds very little so
    it’s very little neede to replace. . On normal circumstances it’s a hr at your leisure , don’t even need wheels off most vehicles .
    Fair enough if you have a pump etc , but considering most people probably only ever do this once on there own car what’s a bit of pipe and a empty 250ml bottle cost.
  15. EmilysDad
    6,297
    663
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    It will. ;) This method is just the reverse of using an Easibleed which pressurises the system at the reservoir and you slacken a nipple off to remove fluid.
  16. Uncle Benz
    2,182
    303
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    When you remove your foot from the brake pedal the entire hydraulic side is relaxed from the reservoir all the way to the calipers. In this mode the fluid has no pressure on it and is free to go to or fro. You can push the pistons back to fit new pads and the fluid will go back to the reservoir. Consequently if you open the bleed nipple the fluid will run out under gravity. A vacuum device just speeds up the progress. Easibleed systems apply pressure to the top of the reservoir to achieve the same speed increase, but they can be messy.
    tedfred likes this.
  17. Oldspanners
    237
    127
    Oct 30, 2017
    Your Mercedes:
    C CLASS 2004 C180
    With the vacuum pump you can suck out the old fluid from the reservoir, top it up with the new and this speeds up the arrival of new fluid at the calipers without having to pump through all the old fluid in the reservoir first.
  18. OP
    tedfred
    112
    29
    Apr 29, 2018
    Your Mercedes:
    slk 200
    Thank to All,
    Thanks for clarifying that for me.
    I always wondered about the Easy bleed system, as to how you complete the work, as removing the easy bleed cap on the totally full reservoir must surely involve spilling a lot of fluid everywhere??
    I think I will go down the vacuum route .
    Thanks to all once again
    Regards
    Tedfred
  19. EmilysDad
    6,297
    663
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    As long as you get air tight connection to the reservoir & bottle then you don't spill fluid. Probably the hardest thing to find these days is a spare wheel to pressurise it. :D
    tedfred likes this.
  20. OP
    tedfred
    112
    29
    Apr 29, 2018
    Your Mercedes:
    slk 200
    Thanks for that again, EmilysDad,
    Just for completeness I assume that I can use standard DOT 4 brake fluid ? Or do I have to use the Mercedes own fluid with added DNA so as to maintain my warranty?? Forgive the cynicism.
    Regards to All
    Tedfred
Share This Page
