C class interior door handle.
waleed89
New Registration
edinburgh
mercedes benz c class w204
car handle broke
my rear door handle broke yesterday. last year got the front one repaired and now its the rear. please malcom is there any chance if you can send the guide. my door wont open at all
regards
wasif
oldjohnny
I 2005 BMW E60 530d. 2012 Mercedes e class estate.
Hi.
2009 C Class has suffered the dreaded passenger door problem and only opens from the outside. I am sure someone may have posted this before (I have just signed up) but I will relay the following details just in case.
An American company called AGA do a repair kit for this, £69 for the part but £37 for the shipping. There is one on ebay from another source at the moment. It is a brilliant long term fix and it saves hundreds on a new panel. The owner/inventor has an excellent tutorial on youtube which is worth viewing. Type in AGA inside door lever panel repair kit. Glue type repairs are possible but could well come adrift again at any time. I contacted AGA direct and their only agent in Europe is in Denmark, www.agatools.eu who are no cheaper unfortunately regarding postage. Part number is AGA-MB-DLK-204. I cannot for the life of me figure out how something so small can cost so much in shipping. If you have a relative/friend in the USA it would be interesting to know the real charges for this.
Hope this helps.
Picasso
W204/2010/C250
Hello, I've had the same problem on the passenger door of my 2010 C250. Could you possibly send me the door documentation? Have seen a couple of different YouTube videos on the matter, but unsure which is the best method.
oldjohnny
As mentioned above, if you type in AGA inside door panel repair kit on youTube you will get the full demo on how to fit this excellent soloution. Expensive but a quarter of the cost of a new panel which will never match the rest. I sold the car on and now both front and back passenger side door handles have gone. It really is a common fault and disgraceful of Mercedes to offer no help on older cars.
Cheers.
Picasso
W204/2010/C250
Thanks oldjohnny. It does look like a good solution and the instruction video looks straightforward, but I'm balking at the price. The kit itself costs $69 but shipping to the UK is $117! So in total around £144 for a small packet of components that probably weighs no more than 200g. I'm going to ask a friend in the US to check shipping costs for me, but it should be far less than the insane charges AGA quote. I agree with you totally, this kind of nonsense is disgraceful on a Mercedes, its supposed to be a marque of quality.
oldjohnny
On ebay at the moment there is a kit for sale at $137.47 dollars all in which is approx £105 sterling if that helps.
I would be really interested to hear what you can get the postage for from your friend. I think the problem is the mad tariffs involved as well.
I'm pretty sure it would be easy to make something up using U channel aluminium, a bolt, nyloc nut and penny washers...
Just cut the U channel and bend it to shape to get the angle then adjust using a cut off disc on a Dremel to get any necessary clearance.
http://www.ebay.co.uk/bhp/aluminium-channel
oldjohnny
Before I sold the car my spannerman drilled just behind the broken piece and attached a really strong cable tie to it and the door panel somehow.. Worked spot on but the fitting on the back door was slightly different and it was not possible to do it there.
romishay
London
09 c220 Cdi Elegance
Dear malcolm
The clamp that holds the outer sheath of the door handle cable has broken away from the door card, mercedes say a new door card at £400,,, the fix is to bond something to the back side of the cad that will allow the cable clamp to be fixed to the card, it should be easy enough to come up with a fix.
Modern polyurethane glues are stronger than what they are stuck to
Dear Malcolm, I hope you are well. Would you be able to please assist me with the diagram on how i can remove the skin so i can repair(attempt) my drivers side handle and rear passenger side handle?
Thanks,
Rommel
L John
W204 C350 Petrol Elegance
Dear malcolm
Thanks,
Rommel
Sadly Malcolm is with the angels now but he did send me the info when I requested it earlier on this thread.
I'd be happy to pass his info on to you if you can send me a PM with your email address.
romishay
London
OMG, so sorry to hear that :( i greatly appreciate the response, am so so grateful. This morning my wife opened the driver side door and it just snapped, and a few months ago my son did the same to the rear.. Merc in South Africa want 17500ZAR
Thank you so so much L john, really appreciate the reply.
L John
No problem at all, I've sent you the info Malcolm gave me and I've deleted your email address from my profile messages so no one can spam you.
The attachment should be in the email as I just forwarded it to you, let me know if you don't get the attachment and good luck getting it sorted.
romishay
London
Thanks L John, greatly appreciated. managed to stick it, but it broke so gave it a 2nd go, hope it holds :)) thx so so much.
Pauldunn1988
C220 62plate
Hi, this problem has happened to my c220 62 plate, on the the drivers side could do with some help as MOT is due in 2 weeks.
Pauldunn1988
C220 62plate
Hi john, would it be possible for you to asssist me in my problem with the drivers side door ?
L John
I can forward the info Malcolm (RIP) sent me by email if you can give me an email address to send to.
L John
You should have it now, edit your email addy out of your post if you can.
If you cant do it a moderator can do it for you.
Pauldunn1988
C220 62plate
Received, thanks very much John unforuney the handle was snapped and was unable to glue it together.
