C200 (W205) AMG Line Door Mirror Puddle Lighting
huddo_uk88
New Registration
C200 2014 AMG Line
Can anyone tell me whether the door mirror puddle lights (underside of the mirror housing) come as standard on the C200 W205 AMG Line. I have looked everywhere but cannot find any reference as to whether or not they do. Plus dealer is a little clueless.
Similarly the exterior door handle lighting, if possible
Has anyone got one (without the Premium or Premium Plus packages) who can confirm?
Cheers, Chris
torvil
Stone, Staffordshire.
C 250 Cdi Blue Efficiency Sport Estate 2011 2.1
How do you get them to work?
I have ambient lighting and can see the led bulbs but it doesn't seem to light up at any point.
ernieh
Scotland, East
Go into the vehicle settings menu and scroll round until you come to lighting. Then select the options you want / need. The on-board handbook describes these operations and there is also an one on-line available for bed-time reading.
Ernie
chrisdean
Liverpool
W205 C200 AMG Line
I've got the premium pack, the tell tale sign are the chrome handle trims which signify LED door lights which incidentally fail, I've had three replaced. I think the mirror lights are standard across the range but "Ambient Lighting" well it's best described as subtle. Any pictures you've seen of it have been photoshopped, that glow in the brochures just doesn't happen.
John Laidlaw
Wirral
Land Rover Discovery 4
Is right- very very subtle....
brilock1
Guys can I jump this thread as you have the same model as me? I am wondering if any of you have a problem with stop start light not going green often? It was fine until a couple of months ago now its all over the place.
Thanks for any comments.
chrisdean
Liverpool
W205 C200 AMG Line
Absolutely, haven't seen it working for a couple of weeks. Perhaps it's because the outside temperature is in single degrees. Tried running with everything off, in eco mode to no avail. I'll give it until April then I'll try and get it fixed under warranty.
brilock1
Thanks, I am not alone then! My previous 220 diesel was never like this, worked flawlessly whatever I threw at it. However this c200 petrol seems not to like going eco in cold weather, although I am sure that it was fine last January 2015 when I bought it.
chrisdean
Liverpool
W205 C200 AMG Line
Bit warmer today and I drove a bit further than usual, it did work but not for more than five minutes.
brilock1
I thought I had it cracked as a low temp issue, so I went out like you today in 7.5c down to 4.5 c tonight and after 48 miles it came on ! so that theory is straight out the window. Now thinking about the Battery? The trouble I find is that the Mercedes guys are fitters and don't understand these problems.
Tel: 020 8863 9233
