ds24215605
- Mar 12, 2010
- Location
- Lancashire
- Mercedes C-230 Sport Auto
Problem: Car was running fine then in the morning came to start it - car wont start.
Actions taken so far by myself. Did the usual visual checks,nothing seemed out of place.
Called AA Home Start.
Actions taken by AA (Who were very thorough) to narrow down what the issue is:
1. Check fuel delivery - pump priming up and running.
2. All fuses in fuse boxes ok.
3. Fuel pump relay ok.
4. Check switching at injectors - ok.
5. Check key fobs remote working ok.
6. Car has fuel in tank.
7. Check for HT spark at plugs - ok.
8. Found that the plugs were dry like the injectors not opening?
9. Car would start if fuel manually fed into carb, albeit only for a short burst until fuel was used.
Unfortunately he didn't have a diagnostic checker to fit the car :-(
Anyone any suggestions what the issue could be, or come across this problem before. I am reluctant to have it transported into a Mercedes Garage for expensive diagnostics.
Conclusion. Is it the fuel pump not building up enough pressure to pump fuel into the injectors? I have only a limited knowledge of DIY on cars, the notes i have typed up from the AA Report.
