C63 wheels for my....diesel !
Waheed82
London
W204 C320 CDI 2007 Saloon
Hi all,
I know there have been lots of threads re: wheel fitments, and to those in the know sorry for asking again !
But, I have found a set of C63 replica wheels that I really want to treat myself to. I have a C320 CDI (57 Plate) which currently has standard 17" wheels.
I'm not too sure of what the forum rules are for posting adverts so here is a snipet of the discription:
5x112 PCD
ET42 - 8.5" front &
9.5" rear X 19"
66.6CB
Load rated to 690KG
So my question is, will these fit on my car ?
Many thanks
I think that 19" might be too big, they are not listed for the 204 that I can see
Rebel-Matt
Lyne
www.facebook.com
RA350D (2012 C350CDI)
the following will fit but beware of changing the width..
8j Wide front is ET45
9J Wide Rear is ET54
Hope that helps,
Rebel-Matt
Lyne
www.facebook.com
Hi all,
5x112 PCD
ET42 - 8.5" front &
9.5" rear X 19"
66.6CB
Load rated to 690KG
Many thanks
If they are ET42 all round they will extend the Front wheels 9mm and the rear wheels 18mm further out then C63 wheels.
Rears may be an issue (very close to sticking out if not sticking out. :)
W
Waheed82
London
Thanks for all the info guys !
Rebel-Matt: Would you say the 9mm and 12mm would be with tyres fitted or without ? I think if its with, then it might actually look good as it'll be very subtle...
Rebel-Matt
Lyne
www.facebook.com
Do you mean 18mm ?
I run 12mm more on the fronts and it looks perfect.
12mm on rear would be just about right (all measurements are rim not tyre) so even with tyres it would site perfect. Stick up a link to the rims you are looking at or pm me and Ill happily look at fitments for you.
Cheers
W
Waheed82
London
Do you mean 18mm ?
Cheers
Thanks for offering to check. The item is on gumtree, if you just enter the ad id it will bring up the item.
Ad id = 1030154016
Do not forget it will be a hard ride with 19" a 35 profile front and 30 rear
W
Waheed82
London
Yes I did consider that - In all honesty I would have kept the current ones but not only are they flaking and very scratched but my front left is also cracked so it seems like a good excuse to change up.
