Caliper sliders
Discussion in 'General Mercedes-Benz Related Discussion' started by EmilysDad, Jul 10, 2018.
  1. EmilysDad
    EmilysDad Senior Member
    5,998
    525
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    I wonder who thought it would be a good idea to use 7mm & 9mm Allen socket on the calipers sliders? Despite having loads of Allen keys I didn't have a 9mm for the front calipers sliders.
    Took car for MOT yesterday, & he picked up that a couple of calipers/discs were binding. Despite new pads all round just a few months ago, the pads on one of the wheels have worn half way through ...... not really very pleased. Oh Well! If you want a job doing properly ....
    Jimbo1959 and Jim2 like this.
  2. Botus
    Botus Senior Member
    2,111
    208
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    fleabay
    lots of fasteners on modern cars, party to stop us fiddling, partly to speed build time in the factory (or I bet that's what they tell themselves). need another 2 tools boxes to fit it all in
    Jim2 likes this.
  3. OP
    EmilysDad
    5,998
    525
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    They're now ordered off eBay, it just p***ed me off that of the many Allen keys I have, both standard & socket drive, I had to leave the front calipers for another day. (I found my 7mm socket drive Allen key for the rears ... last used many moons ago)
    And why are the caliper carriers held on with 18mm headed bolts ...... I thought it was just the Koreans that used odd ball spanners instead of 10, 13, 17 & 19
    Jim2 likes this.
  4. Botus
    Botus Senior Member
    2,111
    208
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    lots of 18 and 21mm bolts on suspension components (get your new sockets ready now)
    I think its all due to the accountants, once upon a time Romans / British invented AF sizes where the material and strength used all lined up to give the right sizes and cost structure for a given loading / strength...
    then a French git tried to take over the world, and some how Japanese guys went metric with 8 10 12 14 17 and 19mm sizes on their motorbikes (where clearly there was more strength and cost than necessary). not to be out done the European car manufactures went ha that's no good I want 11 13 15 16 18 21 24mm
    somewhere in that madness the right size strength material and cost ended up making metric versions almost exactly coming full circle to the AF stuff we already had!!!
    Wighty and EmilysDad like this.
  5. 00slk
    00slk Senior Member
    1,959
    491
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    2002 SL55 AMG, 2003 SL500
    Just had the same issue today when!i decided to check the diff oil level, I have many Allen keys but not a 12mm. I ended up doing my usual and made a tool to undo the filler plug, I have quite a few homemade tools now, best one is the Steering box nut adjuster for the W116, which can be down with the engine in place ;)
  6. OP
    EmilysDad
    5,998
    525
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    I've loads of sockets both hex & torx :)
  7. Wighty
    Wighty Senior Member
    3,471
    1,246
    Aug 4, 2016
    Your Mercedes:
    I find most "new" jobs I do on a car now are split into two parts , firstly check what tools are required which involves checking the garage for an hour , then spending time on eBay to hunt them down when I find they are non standard .
    Then finding another day to do the job .
  8. onefortheroad
    onefortheroad Senior Member
    463
    9
    Dec 8, 2015
    uk.
    Your Mercedes:
    w219 2008
    you could remove the caliper with the carrier , then slide the carrier off the pins , clean pins , re - grease , push caliper piston back and refit pads etc . refit carrier and caliper. you ll need to do this in the event of the pin heads rounding off. ive just had to do this on my 08 cls as the merc pins had star heads which were destroyed in a few turns due to pins having thread lock on them. i ordered new slider pin kits from brakes international and replaced them .
  9. M80
    M80 Senior Member
    2,961
    328
    Jan 21, 2006
    Derbyshire
    Your Mercedes:
    Viano 3.0 ExLWB (09)
    Could always grind down a larger allen key to fit.
  10. OP
    EmilysDad
    5,998
    525
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    I could have ..... just ordered one instead. ;)
  11. Rory
    Rory Senior Member
    4,640
    44
    Feb 8, 2005
    Cheshire, UK
    Your Mercedes:
    2005 C270CDi Avantgarde Estate
    Not sure what's going on but we've had this on a couple of our cars recently. One (a Honda) is under warranty but the dealer thought it was hilarious to take £300 off my daughter. Honda UK didn't give a toss. I'm fuming!
    I don't recall this being a regular issue in the past - but they don't even squirt brake cleaner at the callipers now during service, never mind strip and clean them.
    Wighty likes this.
  12. Submariner1
    Submariner1 Senior Member
    4,122
    470
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
    When I changed my caliper piston boots, I happened to bump into my top mechanic at the dealers when collecting the parts.
    He gave me a tip for the rears. Check or change the rubber sockets for the guide pins. Basiclly these big pins slide in a rubber boot.
    Some people “grease them” with coppa slip. This is mineral oil based and causes the rubber sockets to swell and bind “on” and creates massive pad wear.
    Note MB brake paste is better but not ideal! You cant use Ceratek either , thats mineral based!
    And red rubber is also no good and cant take the heat.
    He also said many MB main dealers do not grease them at all because of the above.
    But there is a Dupont heat resistant rubber safe grease .. this takes the heat, and is rubber safe, so does not swell the pads.
    Using it allows the brake pads to come off instantly, and reduces pad wear.
    Sorry I forgot the name.
    Its well expensive and sold in big tubs. But there is a guy on eBay who decants it into tiny pots for a few £.
    Its over priced for the quantity but still cheap and you only need a little.
    And he was right it works!
    Rory, Wighty and EmilysDad like this.
  13. Submariner1
    4,122
    470
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
Share This Page
