Can a faulty thermostat cause other issues?
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by X308, Jan 9, 2018.
  1. OP
    X308
    X308 Member
    15
    Dec 30, 2017
    Mostly in the Bobby Moore Stand
    Your Mercedes:
    w211 2003 2.7cdi
    I am working on the basis of the following;
    [​IMG]
    Regards,
    X308
  2. Arudge
    Arudge Senior Member
    753
    240
    Jun 14, 2016
    Cradley Heath
    Your Mercedes:
    CLK200 2000 Kompressor
    Mine didn't work at first but was nothing more than a manky connector. It took me longer to find the pump than to fix it.
    It was under the air box.
  3. Botus
    Botus Senior Member
    2,670
    421
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    [​IMG]
    engine 642920
    Variant A 642 010 42 02
    does that mean no heater booster R22/3?
  4. Arudge
    753
    240
    Jun 14, 2016
    Cradley Heath
    Your Mercedes:
    I've done a short clip so you can see for yourself. I followed the exact same procedure that you did. Pos 1, then pos2, start, load all the electrics. It was a cold start so the idle is a little higher than normal, about 800rpm. It wasn't revved any higher.
Share This Page
