d215yq
- Mar 28, 2008
- Age
- 39
- Location
- Valencia, Spain
- 1987 W124 300D 280k miles
Hi all, not exactly mission critical but as I've not had to fix anything for quite a while now and holidyas are over time to address the washers. For a long time now I've only had 1.5 of the 4 washer jets working. After playing around with them with a needle I managed to get 2 briefly working (those on drivers side) but now back to just 1..
The needle goes right into 3 of the washer jets (one is so crudded it seems like it's welded shut and you can't even see the hole) but I'd be happy with 3 of 4. I've tried removing them from car and no luck.
So I'm now almost on empty so can I just put a little drain unblocker in the tank and then run the jets a fair bit (and then once run through fill with water to flush it out). The drain unblocker on sale here is pretty potent stuff but I'm guessing that the components of the washer jets are more or less the same as that of a typical drain pipe (rubber, metal and plastic) so should be OK??
Not too bothered if the drain unblocker discolours the paint when it sprays, this car is a working vehicle and already has quite a patina. Will it destroy the windscreen glass though? Suppose I could put something over the jets to capture it exiting if this is a problem.
Thanks,
Ben
PS car is 1987 W124 300D as in signature.
Thanks,
Ben
