[Spares] Capacitive Fingerprint Reader - DIY Kit
Discussion in 'Spares for Sale and Wanted' started by GLK, Sep 2, 2018.
  1. GLK
    GLK Senior Member
    2,802
    835
    Sep 19, 2014
    Northampton
    Your Mercedes:
    A200 Avantgarde Special Edition Sports Coupé • C169
    I have this Capacitive Fingerprint Reader, which I bought not long ago, for a project, that never materialised (I was going to fit it either in OCP or in the windows door switch pack).
    R303 Capacitive Fingerprint Reader with two different mounts.
    The fingerprint scanner is of a high quality, and can be used in either home, or vehicle security installation, Arduino - based.
    Total cost for all three components (scanner and two mounts) was about £35 direct from China.
    For sale at £20 delivered in the UK.
    The original spec & description (copied from a Chinese site):
    Fingerprint reader R303 (semiconductor)
    Main Functions:
    Communication interface: USB and UART
    1:N Identification (One-to-Many)
    1:1 Verification (One-to-One)
    High speed fingerprint identification algorithm engine
    Self study function
    Fingerprint feature data read/write functions
    Get Feature Data of Captured fingerprint and Verify/Identify
    Downloaded Feature withCaptured fingerprintIdentify
    Downloaded Feature with Captured fingerprint
    Security Level setting: able to set BaudRate / Device ID / Device Password
    Operating system: Windows 98, Me, NT4.0, 2000, XP,WIN 7 or Android
    Specification:
    Fingerprint capacity: 1000
    FAR< 0.001% (Security Level:3 )
    FRR< 0.1% (Security Level:3 )
    Fingerprint template size: 512 Bytes
    Security level: 1-5, default is 3
    Fingerprint reader module size: 20 * 32 (mm)
    Sensing array: 208*288 pixel
    Effective collection area: 11 * 15 (mm)
    Resolution: 508 DPI
    Time of Response: Fingerprint pretreatment < 0.2 s
    1:N < 0.3s
    Communication mode: USB2.0 UART (3.3V-TTL logic)
    UART Communication
    Parity = NONE, Stop Bit = 1,
    Baud rate support: Default is 57600BPS
    Power Supply: Voltage DC4.2V-6V
    Work current: <55mA
    Working Environmen:Working temperature : -20ºC to +55ºC
    Working Humidity:20% – 80%
    You can dowload R303 user manual from the following website:
    https://www.dropbox.com/sh/orprmb3bgb6lqb6/AACpiIXOF91R7-RQ9OkD4JXha?dl=0
    _______________________________
    Links to the original items:
    https://www.aliexpress.com/item/R30...Reader-Module-Sensor-Scanner/32620290283.html
    https://www.aliexpress.com/item/Enc...-and-chip-of-model-FPC1011F3/32808632569.html
    https://www.aliexpress.com/item/Str...le-R301-R302-R303-R305F-R306/32808688304.html
    Pics:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. OP
    GLK
    GLK Senior Member
    2,802
    835
    Sep 19, 2014
    Northampton
    Your Mercedes:
    Bump! Still available :)
  3. OP
    GLK
    GLK Senior Member
    2,802
    835
    Sep 19, 2014
    Northampton
    Your Mercedes:
  4. OP
    GLK
    GLK Senior Member
    2,802
    835
    Sep 19, 2014
    Northampton
    Your Mercedes:
Share This Page
