Chassis rust, Is this too far gone.
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by alexanderfoti, Nov 29, 2018.
  1. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    10,499
    1,265
    Mar 25, 2010
    Dartford
    Your Mercedes:
    Hi all
    Pulling apart my Cl55, and am finding lots of rust under paintwork.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    This is the rear subframe mounting area, behind the wheel arch trim. Not sure I like the look of the rear subframe mounting area.
    This is the subframe and boot floor underneath.
    The sill jacking point are also a tad rotten, where ill fitting jacks etc have been used in the past.
    I think, if repairable, it will need a new subframe (or to dip this one) and treat all the rust on all 4 subframe mounting points and the sills along the length of the car.
    I think I have made my mind up, but would like others thoughts on it.
  2. daveenty
    daveenty Senior Member
    2,746
    748
    Jun 21, 2005
    The Frozen North :(
    Your Mercedes:
    2017 W213 E63s & 1989 W201 2.5-16
    I'd drop the subframe off it and then go through it all thoroughly before making any decisions.
    My little 190E wasn't as bad looking as that but, when all the paint and rust was stripped off it, it still took a while to get back to an acceptable (to me) standard. Lots of strip and clean pads and wire brush drill attachments were sacrificed, but worth it in the end.
    Once all that rear suspension's off the car it's a lot easier to work on as well. :)
  3. OP
    10,499
    1,265
    Mar 25, 2010
    Dartford
    Your Mercedes:
    I think that is the best option.
    The rust you see on the side sections, is after I scraped back to clean metal with a screwdriver, so less likely to be hidden under paint at least.
    Ill drop the subframe and the sideskirts and see whats what.
  4. LostKiwi
    LostKiwi Senior Member
    14,997
    6,068
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    You've clearly never owned a Land Rover.... That would be considered excellent!
    thebiglad, Wighty, GLK and 3 others like this.
  5. OP
    10,499
    1,265
    Mar 25, 2010
    Dartford
    Your Mercedes:
    At least MB's consistently have truly random rust effects.
    03 CL55 W/86k like this
    02 C270 CDI W/122k nowhere near as bad...
  6. Uncle Benz
    Uncle Benz Senior Member
    2,280
    428
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    That is certainly no surprise given its age. Subframe out is probably a good shout. Have a good poke. If you can make a hole it'll need a bit of welding. If you can't poke through then grind the worst off, treat the rust and go for some decent paint-over-rust product. Keep an eye once a year. Treat again as necessary. I've welded up a couple of my customers w220 S classes in this area. Not difficult to do. Have a look at 2002 Fords if you want a laugh. People moan about rust on Mercedes, but Fords of a similar vintage rot horribly underneath, and the struggle is usually to find good metal you can weld to. What starts as a hole a half inch long can quickly become a foot long horror story. Anyone who has welded rusty cars will know what I mean when I say you feel sick to the stomach as you keep digging, and it keeps getting worse and worse!
    To be honest Mercedes are usually pretty mothy around the arches and bumper joints before the rust on the underparts gets serious.
    Blobcat likes this.
  7. Blobcat
    Blobcat Moderator
    9,850
    829
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    I was about to post the same, I don’t think my Land Rover had that little rust when it was new...
    Wighty, alexanderfoti and LostKiwi like this.
  8. OP
    10,499
    1,265
    Mar 25, 2010
    Dartford
    Your Mercedes:
    Absolutely. Its all still solid, no holes can be made, although I have found a small hole under the drivers seat. I think its worth pulling most of the bits off, as you say.
    I think its a good stage to keep on top of it before it goes any further.
    What I typically do with rust, is grind down to good metal, where possible, and then treat with Deox gel. Once done, I clean off and spray etc primer, then either a stonechip guard or a colour coat, depending where it is. I have little body shop experience, but this has done me ok in the past?
    This particular car has had a good quality, full respray, so the outside is nice with no corrosion in the usual places. A bit odd why they didn't do a proper job when they had the opportunity, as the paint job is top quality....
    I intend for this car to be a show vehicle for what is possible with tuning on the 55k platform, so it needs to keep going for a bit :)
    Wighty and Blobcat like this.
  9. OP
    10,499
    1,265
    Mar 25, 2010
    Dartford
    Your Mercedes:
    Maybe I should (nt) buy a LR then? :)
  10. Blobcat
    Blobcat Moderator
    9,850
    829
    Your Mercedes:
    They’re appreciating assets! so if you want to make money by a Land Rover (or a 911). Just get a decent welder...
  11. Uncle Benz
    2,280
    428
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    Have a look at POR15 if you aren't aware of it. It's pretty good if you follow the application process.
    bembo449 likes this.
  12. OP
    10,499
    1,265
    Mar 25, 2010
    Dartford
    Your Mercedes:
    I have used it in the past, but not had any of the vehicles long enough to observe the long term effects.
    Im torn between, grind, acid, prime, paint, protect (bilt hamber) or POR15 treatment.
  13. bembo449
    bembo449 Senior Member
    2,664
    473
    Jan 2, 2012
    lincolnshire
    Your Mercedes:
    216 5.5 v8 , range rover vogue , 221 320cdi , alfa romeo brera
    or early 2000's model kia or Hyundai
  14. Frontstep
    Frontstep Senior Member
    6,403
    448
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    I must hunt out my Mobilo warranty.
    om613 likes this.
  15. om613
    om613 Senior Member
    1,298
    242
    Aug 29, 2015
    london
    Your Mercedes:
    S202 C250TD, S123 240TD
    Either would be fine.
    Yes, that's what we do ... to benefit the next owner.
    alexanderfoti likes this.
  16. thebiglad
    thebiglad Senior Member
    297
    146
    Aug 15, 2018
    Central France
    Your Mercedes:
    2005 CLK 270 cdi
    LR Discoverys TDi200 and 300 - bodies would rust like a paying hobby : Boot floor, wheel arches, floor, inner and outer sills, front inner wings. Chassis is normally good.
    Discovery II TD5 - Rear chassis can be like lace it rusts so bad. Bodies are usually surprisingly good.
    Discovery III TDv6 - Good all over.
    Defender - Rear crossmember, doors, front bulkhead all bad. However galvanised chassis, doors and bulkhead are now avail.
  17. Blobcat
    Blobcat Moderator
    9,850
    829
    Your Mercedes:
    Yes, however that takes all the fun out of ownership...:rolleyes:
  18. charlysays
    charlysays Senior Member
    148
    19
    Jan 11, 2016
    Pembrokeshire
    Your Mercedes:
    Mercedes C250 Turbodiesel Sport Auto Estate
    That looks in pretty good shape to me tbh, I'd be very surprised if there were any holes.
    My first W202 was a lot worse on the subframe mountings, as was my second. my third is better than the first two and probably better than yours but not by much.
    I just walloped off all the scale I could with a hammer through screwdriver, chiselled the underseal off to expose it fully, treated with bilt hydrate 80, couple of coats of electrix then loads of dynax. 5 years later it was still rock solid.
    I strongly recommend you check out a Kobe compact needle scaler. Will make prepping body work so much easier, even stripping back underseal.
    om613 and Wighty like this.
  19. peterws1957
    peterws1957 Senior Member
    521
    182
    Apr 3, 2016
    Lancashire
    Your Mercedes:
    I've used POR15 a lot in the past, but always on top of metal where I've removed 99% of the rust by acid dipping wire wheeling or media blasting. Use their metal prep first though. Did the underside of floorpans on one car and its still shiny and rust free 10 years later. You can paint on top of the coating as well. Expensive stuff but I think worth it. Don't get paint on the edge on the can lid though- you'll have to chisel the lid off!
  20. thebiglad
    297
    146
    Aug 15, 2018
    Central France
    Your Mercedes:
    2005 CLK 270 cdi
    Looking at the back end of the chassis (rear of the rear axle) on Discovery II's - some of them are literally like lace.
Share This Page
