Check this out , a secret rust spot behind strut
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Took off wheel of my 07 e 320 and found these 3 pockets full of dried up dirt which as you can see was causing rust to start , I had to bend a screw driver to dig them out and scrape off excess rust then blew the pockets out with air gun there’s drains in here but once they get wet muck that’s them disabled , I only saw this by luck so if anyone has there wheel off clean out these 3 holes behind the strut . I am rust treating mine now and going to pack the pockets up with good filler so no more muck can gather and will shape them high at the back so water runs straight out. Hope this helps someone out before it rots away on them. Sorry if someone else already posted this I could not find anything , the photo of dirt on the floor came out of these 3 pockets sitting on top of the chassis just behind the strut.
BB9F047C-D8E7-4B9B-AAE1-6BB6296A6935.jpeg B10CC73D-3910-430F-B2B4-73F6453FA346.jpeg 1E9A0102-BEC0-4074-8CCA-767145FFF9D4.jpeg 44CB9AC7-9494-4395-B81B-5750C0831431.jpeg
That brake pipe in picture 2 looks like it's suffering a bit .
EmilysDad
Bury Lancs
ML350
I dare say there'll be other pockets of rust around & about under your car ..... there is on my 07 car too ;)
mercmancdi
mercmancdi
No not as bad as it looks thank goodness. There’s bits of rust and dust stuck to it as I had greased it before I discovered the rust ,
Needs wiped down and redone.
mercmancdi
mercmancdi
It’s like a treasure hunt only you find rust instead of treasure. Lol
I think those pockets are a design
fault , or are they.
Submariner1
Windsor Berkshire
CL500 2009 5.5
Being the first car for decades I have crawled under. I was very pleasantly surprised to see all the seams had sort of painted mastic on them on the CL500.
Most of it seems to be ally, but useful on the steel bits.
As the mastic is rock solid and either side is sound paintwork I remain optimistic its not rusti g away underneath the mastic LOL :)
I noticed yours didnt have the mastic ... wonder if its like that on all E Classes? Or that one was unlucky.
Taffy7hfa
Oxford
Good save !
mercmancdi
mercmancdi
I think I took everything off all round the entire inner wing , the rusts not as bad as it looks as it’s on heavy metal but the dirt was built up and caked hard as cement , a wire brush won’t
Even scratch it I had to start with a old wood chisel then bent an old screw driver to get down into the well
I have got a good first coat of rust treatment on by hand , if I can tomorrow going to spray in there with fertan then finish with body Schultz
mercmancdi
mercmancdi
I have had 2 kugas the oldest was 5
Both of them leaked water in the boot
And started to rust from the inside out , I was back and forth to ford like a yo yo but they always failed to fix it
in the end I threw it back and got full
refund , but they should have paid me more for the stress and hassle.
The other one I owned you could hear the insulation foam splash in the back. Needless to say it got a swift shift down the Rd.
mercmancdi
mercmancdi
Got inners sprayed with fertan today
just have to wait to it’s all dried in and coat with Schultz , and did a little experiment and painted calliper yellow FE798353-22AE-46D7-B742-57CB55A96118.jpeg 57FD94C0-8B35-411C-8B60-501F67E3AF0B.jpeg 61415B02-743D-42A1-ADC7-337DCDB21F54.jpeg 261E1431-2BEE-4FB7-8F91-E841A75B4C7E.jpeg
