The centre connector sometimes fails, mine had to be changed, luckily FOC by the main dealer.
Jiggling around occasionally got a momentary connection so I knew mine had power to the socket.
Get a test meter and check for continuity between the outer section and a good earth point.
Then check for voltage between the centre pin inside the socket and earth (with the ignition on).
Peter Best Insurance is a leading specialist in Mercedes-Benz insurance. All MBO members are eligible for exclusive rates on all our classic car policies. Call now for our 'BEST' quote. Tel: 01376 573033
