Dalton316
New Registration
- Jun 21, 2018
- Clk200 kompressor convertible 2000
Hi I'm hoping someone can help I purchased a second hand mercedes clk 200 kompressor cabriolet on a 2000 y plate . When driving today I seen a fault pop on screen saying engine fan warning . I switched off car waited a few hours and reran I noticed that the rad fan was turning slowly and squeaking stopped car again checked the fuses all good decided to take fan off cleaned and tested it on a 12v battery and fan turned perfectly no squeaking and really fast reinserted into car an stool another run after 30 mins the warning came up on screen again checked the fan and it is turning slowly and squeaking. I'm wondering if there is a temp sensor fault too car or a speed control sensor fault on vehicle if so where are they located and has anyone ever had this and got an answer too what could be causing it I've tried an obd scanner but it shows 0 faults all help would be greatfully appreciated tia
