Coupe
- Jul 13, 2009
- Location
- Esher, Surrey
- 2002 CLK 2.3K Convertible
Rear coupling - I can remove the bolts (extra leverage required!) loosen the coupling from both the prop shaft and the diff end, move the prop shaft back a little way (1-2") but there seems to be a middle central shaft that stops you dropping the coupling. Do you have to remove the front end too to get sufficient clearance or am I missing something. Help please.
