barnaclebill15
- Mar 24, 2015
- Location
- newcastle upon tyne
- clk220cdi/2006/diesel
For over 60k since I had a second hand box fitted all has been ok, had a few things to get done on Friday by my local indie including changing the ATF and filter.
On Thursday the transmission stuck in a high gear, noticed when pulling away from lights also it would not change on manual, stopped switched off and restarted all ok, when I dropped it off for service I mentioned what happened and they said probably needs the ATF changing which we are doing.
Picked it up at 5pm and heard the garage is on holiday for two weeks, drove home and just as I arrived it felt as if it was not changing.
Saturday it stuck in a high gear once but reset ok after switch off and on, today after about 30 miles with a couple of stops all ok got home but had forgotten something drove back out and was stuck in a low gear, stopped switched off restarted but still the same.
Can reverse ok go into park, stop and start but stays in a low gear 3000 rpm to reach 40 mph, tried to change mode from S to C but not changing that either.
Wonder if it's high temperature, oil not circulating the cooler as every time it's when I have covered a few miles before the problem starts, will leave it for a couple of hours and try it again.
This is worse than before I changed the box last time, at least then it would reset ok although it failed in neutral then
