CLK55 AMG Roof hinge help
Discussion in 'AMG' started by Jonnyboy82, May 10, 2018.
  1. Jonnyboy82
    Jonnyboy82 Active Member
    29
    3
    May 10, 2018
    Your Mercedes:
    Clk55 AMG convertible
    So after owning the car less than a week I went to put the roof up and I heard a crack, like plastic snapped. Any way upon inspection somehow this flap/hinge got wedged on the actual soft top during the closing precedure.
    [​IMG]
    It was wedged between the roof and I had to release it but upon so it seems to have lightly grazed the fabric on the roof, luckily not too bad though! So the actual bracket below was bent by me upon removing the flap..
    [​IMG]
    So is it possible to replace the whole part as I have tried twice to bend it back into shape but it’s just not happening. You can see exactly how bent the bracket is here if you compare to the side that’s flush.
    [​IMG]
    Sent from my iPhone using Tapatalk Pro
  2. John Laidlaw
    John Laidlaw Senior Member
    17,664
    4,319
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    You probably want to post this also on the ‘Bodywork........etc etc’ section too as it’s not directly AMG and common to other CLK non AMG models. More chance of a ‘hit’ there
    Jonnyboy82 likes this.
  3. SJMaxwell
    SJMaxwell Senior Member
    547
    33
    Aug 15, 2003
    Chatham
    Your Mercedes:
    2012 E Class E63 PPP + 2012 SLK55 AMG
  4. OP
    Jonnyboy82
    29
    3
    May 10, 2018
    Your Mercedes:
    Thank you matey, although I have managed to source the part from eBay for £30 as opposed to £137+Vat from Mercedes!
    peterws1957 and Wighty like this.
  5. peterws1957
    peterws1957 Senior Member
    521
    182
    Apr 3, 2016
    Lancashire
    Your Mercedes:
    Cheap repair then:)
  6. OP
    Jonnyboy82
    29
    3
    May 10, 2018
    Your Mercedes:
    Yes hopefully it’s a simple job to replace looks fairly straightforward! Still doesnt explain why it happened though? Now I’m always going to have the worry of it happening again every time I operate the roof!
Share This Page
