SteveX
- Oct 27, 2009
Hi Chaps,
Some assistance would be appreciated as this is driving me insane.
My car had zero noises and drove fine, fast forward to MOT time he said the bottom two arms had play on the driver side.
So I replaced the two arms and when it was back together I have a clunk over bumps at speed from the drivers strut?
I removed the strut and found some play, if I press down on the top mount and let go / bounce it, it makes a small clunk. The top mount was also split, so I replaced top mounts on both sides.
The clunk is still there?
I've disconnected the ARB that didn't help so it isn't coming from there and removed the shock / strut again.
With the new top mount on if I bounce on the top of the mount with my weight it makes a clunk when the shock reaches it's maximum travel?
The lock nut for the strut was screwed down tight and the same as the other side which is fine. I really have no idea?
It was fine before I removed like I said and then the clunk started. It's almost like there is too much travel, but if I tighten the lock nut down any more it will jam the bearing and rubber top mount so I don't want to do that and damage it.
Any ideas?
Many thanks.
Any ideas?
Many thanks.
