Cluster lights don’t work even after changing bulb
Discussion in 'Tuning, Styling and Performance.' started by Linuus, May 4, 2018.
  1. Linuus
    Linuus Senior Member
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    Hi, guys need to “light” here as I can’t figure out what can be causing this.
    A few weeks 2x T5 bulbs from my cluster stop working and they weren’t blowed. So I took the time to order 2x T5 leds and 6x 509T leds. They work fine for 2 weeks
    [​IMG]
    And then 2 weeks later
    [​IMG]
    The 2x T5 died...
    So I removed the cluster and replaced with another T5 and this time they don’t switch ON and for some reason 2 x 509T LEDs stoped working too.
    [​IMG]
    In the pictures the one with a #RED mark are the ones not working... and the ones with #GREEN mark are working fine... any ideia!?
    I have opened up the cluster to check for any capacitor and resistor damage but Notting :/
    Another question if I replace the cluster for a second hand with the register miles be the ones I have or the ones the cluster donor had?!
  2. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    I’m a bit is dispare :/
    iPhone-tapatalk- e320 wagon
  3. LostKiwi
    LostKiwi Senior Member
    13,399
    4,927
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    LEDs are directional. They will only work if inserted one way. Take them ot, turn them 180 and try again.
    I often wonder if the hassles from LED are really worth it.
    DREAMER NO2 and Linuus like this.
  4. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    I have done that... but Notting, they where working just fine. And then a blackout.
    I even swop around with the ones working at the bottom and Notting :/ is there any change I can have damage the top circuits?!
  5. LostKiwi
    13,399
    4,927
    Aug 25, 2006
    Your Mercedes:
    Go back to basics....
    Put an ordinary bulb in to test with.
    One thing you may have done is reduced the brightness of the lights using the dimmer so there is insufficient power to trigger the LEDs?
    Linuus likes this.
  6. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    I have checked the dimming on the left it’s full britgness. I’m thinking is the top circuit works in parallel, where they will work only if all the 4bulbs are ok.?
  7. LostKiwi
    13,399
    4,927
    Aug 25, 2006
    Your Mercedes:
    Parallel would mean they all sit across 12v so are independent. Try going back to basics and fitting bulbs to test.
    Linuus likes this.
  8. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    Will order some. I haven’t seen 2w T5.. can I fill bulbs with less watts like 1.2w.. that’s the ones I have found around.
  9. LostKiwi
    13,399
    4,927
    Aug 25, 2006
    Your Mercedes:
    Yes. They'll just be a bit dimmer.
    Linuus likes this.
  10. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    Will do it tonight just got 2 bulbs will check voltage where the bulbs go and see if a get any readings
  11. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    So, I have fitted new bulbs in and no ligh :/ is it possible I kill the tracks of capacitor?!
  12. LostKiwi
    13,399
    4,927
    Aug 25, 2006
    Your Mercedes:
    It does sound like you've killed something in the cluster.
  13. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    Damn.... I’ve learn one thing then, changing cluster to LEDs can end up with a big bill.
    Second hand cluster + find someone to correct the mileage on the car will leave me water slim.... ;(
  14. om613
    om613 Senior Member
    1,213
    225
    Aug 29, 2015
    london
    Your Mercedes:
    S202 C250TD, S123 240TD
    I've one with 150K on the clock.
    I know this is accurate...because I waited 18 months for mine to catch up before swapping out.
    Yes, a pixel fix that works.
    Linuus likes this.
  15. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    The PCB board looks ok. No crack on soldering, capacitors ok. Tracks ok.... continuity present
    [​IMG]
    Here we can see that the bulbs had melted down a bit of the plastic within some time
    [​IMG]
    [​IMG]
  16. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    I have sent u a PM @om613
  17. DREAMER NO2
    DREAMER NO2 Senior Member
    2,357
    215
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    Next thing they will be fitting sodium industrial light bulbs next. It only want one bright spark to fathom it out .
  18. OP
    Linuus
    201
    56
    Dec 5, 2017
    crawley
    Your Mercedes:
    w210 wagon
    Only solution for me will be replacing the cluster and never ever replace with LEDs even if MB asks 2.99£ per bulb...
  19. L John
    L John Senior Member
    2,609
    395
    Nov 24, 2013
    Your Mercedes:
    W204 C350 Petrol Elegance
    An LED has a much higher resistance than a standard bulb, so I can't see an LED doing any damage and it cant do any damage if it's fitted the wrong way around, it just wont light up.
    When working on anything electronic like this, it's worth using an anti static wrist strap.
    I'd guess static damage or the ribbon /connector has a bad connection or is damaged.
  20. DREAMER NO2
    2,357
    215
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103
    These are made to work with one type of bulb .So after changing them out you left with a problem .Thats how it goes .
Share This Page
