Tony Russell
- Jul 23, 2009
Hello,
Over the past couple of days, I have noticed the odd sticky gear change, until today when I have to stop the car and switch if off, then start it in gear to change gear.
Last thing this evening, if I started it in gear, it was actually partially engaged and moving on the starter.
It's an A Calss Vaneo 1.7 CDi BTW.
So the clutch pedal is a bit floppy. There's a fair bit of travel before the only effective bit of the pedal movement is in the last 2cm or so.
There is no problem with slippage, whining, smells or any other clutch type symptoms.
I called a couple of clutch specialists today who either refused the job because it's a dog to drop the engine and change the clutch, or quoted a lot of money.
Changing a fuse just about requires an engine removal on this beast.
Personally, I don't think it's the clutch, I think it's the hydraulics.
Either air in the system (the low pressure feed from the reservoir to the master cylinder was split months ago and I replaced it - no problems since), or else the seals in the master cylinder might have an issue.
There's no leakage on the carpet or anything, and no loss of fluid from the reservoir.
I understand that the slave cylinder is in the clutch housing, so it's back to the full job if that's the case.
I'm clinging to the possible diagnosis I saw in the Peter Russek manual that suggests a bleed or a master cylinder replacement is a cure.
So, I guess I am asking if anyone has any experience of this particular car / symptom ?
Thanks in advance.
Tony
Thanks in advance.
Tony
